First post, by tje
Suspect this might be a lost cause, or far too niche, but I figured it doesn't hurt to put it out there and ask.
I have an intel L4440GX board, a nice dual p3 500 that I'm looking to build an NT4 machine from. https://theretroweb.com/motherboards/s/intel-l440gx
Having made the textbook mistake of looking at it and thinking "ooh, PCI-X - I'll get a nice gig ethernet card" then realising, that whilst it looks very simiilar, a Raidport is not a PCI-X slot, I then RTFM and went looking for the right Raidport card to turn the on-board scsi into RAID. Given my want to use spinning rust, I figured having a mirrored set of vintage spinning rust was likely to be worthwhile in future.
The on board scsi is working fine, it shows the adaptec scsiselect bios, and my disks show, can be LLF'd etc (even though it only shows ~9gb of my 146gb drive - but I can deal with that).
I found this - https://www.ebay.co.uk/itm/111833859280 which looks to be the correct item, and so got it. I actually got 2, as one arrived without a dimm, and both cards behave the same, so reasonably sure this isn't a hardware failure issue.
It plugs in, the LED lights, but there's no bios on boot. When I boot to dos, and try and the disk based bios update, it initially detects the card, and tries to flash, but then boms out and says card not present.
Upon closer inspection, this card has a sticker on it saing that it's a ARO-1130A/HP - suggesting this might be an OEM HP part. I now thing that it's likely there's some sort of bios / vendor lock.
Anyone got any suggestions before I throw in the towel? I'm wondering if there's anyone who's seen similar, and has managed to maybe force cross flash between firmware / bios.
My fall-back option is to put the raidport card back in the box and live with regular disks on the standard scsi controller.
As always, any insight appreciated 😀 thank you all.
