First post, by mig81
Hi, I need your help to switch on this old motherboard ibm xt clone for 8088. There arent common P8 P9 plugs....which kind shuold i use to test it?
Thanks
Reply 1 of 10, by mig81
Sorry, this photo...
Reply 2 of 10, by dominusprog
You can use any AT power supply, but you should remove the second wire on the P8 connector (+5V) just to be on the safe side.
https://www.youtube.com/watch?v=B_jvQPLj-WE
Reply 3 of 10, by mig81
Thanks alot, tomorrow i'll try!
Reply 4 of 10, by dominusprog
mig81 wrote on 2024-05-23, 21:39:
Before connecting anything to the board, check all the tantalum caps first.
Reply 5 of 10, by Horun
Yes use a standard AT supply. The XT PSU board header is slightly different shaped than from 286 and up. You may have some trouble trying to insert the AT psu sockets, usually if you do it at a slight angle it can done....
make sure the black leads are in the middle !
Reply 6 of 10, by mig81
I tried to connect p8 p9 (p8 without +5) and not switch on, no beep, only a little fash on the mobo led. If i comnect only p9, mobo led lights and beeps furiously.
Any ideas?
Reply 7 of 10, by dominusprog
mig81 wrote on 2024-05-25, 18:12:
Any ideas?
What kind of beep? Continuous beep can be the result of a short on the motherboard, have you checked the tantalum caps?
Reply 8 of 10, by mig81
Continuous beep...but I think it's because I have to connect even p9. On the board i cannot see tantalium caps....if i cannect p8 and p9, no beeps and only a little flash of the mobo led. I think there is a short and the power supply is blocked by the mobo...cpuld be?
Reply 9 of 10, by dominusprog
mig81 wrote on 2024-05-25, 20:10:
So you've connected a power supply without checking it first? The tantalum caps are beside the keyboard connector, you have to check them all (which include the blue ones) with a multimeter.
Reply 10 of 10, by mig81
dominusprog wrote on 2024-05-26, 15:56:
Ok man, tomorrow I'll try to check all the caps with a multimeter fir capacitors, i should have one. Thanks
