First post, by leileilol
- l33t++
486 pooter
AM5x86-133, clocked at 160MHz
M919 rev 3.4 AT motherboard (4 ISA, 1 VLB, 3 PCI, 4 72-pin SIMMS, Socket 3)
AMIBIOS 10/10/94, WinBIOS omg!! (I wish I could make screenshots of the WinBIOS interface, its so much better than later AMIBIOS revisions)
STB Powergraph s3 Trio 64v+ 1MB
Sound Blaster AWE32, 8mb memory
3COM 3C-905TX PCI Ethernet card
Windows 98SE + Windows 2000 SP4
Maxtor 13GB HD (set as 7GB)
Performs in Quake well at around 12fps avg (not too shabby really)
Also can play Zdoom and Odamex doom source ports at stable 25fps.
Cinebench r10 scores: 13 CB-CPU, 193 CB-GFX
Issues:
- Serial port issues (MOUSE JUMPING!)
- Lack of TSC (Timestamp clock) means detecting CPU mhz in some apps like dxdiag and ff7config causes a nice segfault.
- Can't install DirectX 8.x or 9. DirectX 7 is the best DirectX you can possibly install on a 486 cpu.
- Under Windows 2000,ethernet card hogs loads of cpu, and stops completely without any more packets after a minute
