First post, by Malik
I have a peculiar problem here.
I've got myself a Elpina Socket 7 Based motherboard and went about testing it.
Test Setup:
Elpina Pentium MMX Motherboard (Amptron PM-8400 Rev 5.2A)
VX_Pro+ Chipset
Pentium 133MHz CPU
64MB EDO RAM. (Voltage set at 5v)
PCI Slots: i - Voodoo2 8MB
ii - Diamond Stealth3D 2000
iii - D-Link 528TX Ethernet Adapter
ISA Slots : a - LAPC-I
b. - AWE32 CT3980
PSU : Newly installed 350W (which comes with the -5v rail) with ATX to AT wire with switch
Symptoms:
The system won't boot-up after installing the LAPC-I card. After removing the card, everything works perfectly.
Won't boot in the sense, I can see the fan, power come online but no boot-up screen and the usual single beep is not heard from the pc speaker.
Notes:
i - I have used the exact same setup with another motherboard - a SIS 5512/3 socket 5 based mobo, where everything works perfectly. Including the LAPC-I.
ii - The board came with the Original manual (bless that seller). And I have setup all the jumpers accordingly.
iii - I've played around in bios, setting up things like reserving the IRQ9 for legacy ISA and so on.
iv - I've tried changing to other ISA slots. - Nothing happened.
v - I've tried resetting the CMOS and cleared the PCI/PNP configuration. - Still nothing.
I really like this board since,
1. Newer BIOS supporting multiple boot selection
2. PS/2 Mouse header
3. Gold plated connectors - the power supply, IDE, FDD connectors
What I don't like :
1. Baby-AT mobo.
2.The CPU socket is situated opposite to the PCI slots. I just managed to push the Voodoo2 a bit so that it won't get obstructed by the cpu heatsink. Adding another Voodoo2 SLI is a no go.
Otherwise, it works solid.
I really will appreciate any help regarding how to make the LAPC-I run on this baby.
Reply 3 of 17, by Malik
So, I found what was the problem - The MOTHERBOARD!!!!!! 😁
Oh, well, I guess, I'll just revert to my trusty socket 5 based SIS motherboard.
Thanks a lot!!
Really appreciated your enlightening words. I won't be meddling with this board again for the sake of my LAPC-I. 😀
Reply 4 of 17, by Amigaz
Malik wrote:
So, I found what was the problem - The MOTHERBOARD!!!!!! :happyhappy: Oh, well, I guess, I'll just revert to my trusty socket 5 […]
Thanks a lot!!
I had one of these board that came with a nice baby AT tower...when I found out PC Chips was behind it all it went into the bin 😜
The board was paper thin as all of their other boards.... 🙁
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 5 of 17, by swaaye
🤣. I like how the part number so closely resembles that of Intel 430VX.
I'm sure you would be much better off with a real Intel 430FX, HX, or VX chipset.
Reply 6 of 17, by Malik
Yep. Very deceiving indeed!
I have reinstalled the SIS 5501/2/3 chipset based motherboard. And the LAPC-I works like charm! 😀
I'll be looking in ebay again for a good AT based Socket 7 motherboard to go along with my AT casing. I don't feel like putting away my AT mini-tower. Too many good memories with it!
The LED display showing the PC speed sort of resembling the cute messsages shown on the MT-32's display! 😁
Reply 8 of 17, by Malik
keropi wrote:
what about the mobo I use on my k6-II machine? the gigabyte ga-5ax ... works perfect to my knowledge Malik! 😀
Thanks! I'll look for one right away! 😀
Reply 9 of 17, by elianda
Looks like an Elpina M537D Mainboard.
VPX Pro+ is in reality a VIA Apollo VPX chipset.
I had no problems with such board so far, but it's nothing special either.
FSB 50 to 83 MHz, Multi upto 3x, Voltage 2.5 to 3.5 V.
If you want something rock solid stable, go for a HX Mainboard like the Gigabyte GA586HX (or GA586HX2). The Asus HX board will do it too, though has only 4 Mem Slots. If you want something for Super Socket 7, try to get a VIA MVP3 or Ali Alladin Pro. FIC-VA503+ f.e.
But these usually show more edges than the HX.
Youtube Channel
Reply 10 of 17, by Malik
Thanks a lot for the info, elianda!
Reply 11 of 17, by swaaye
http://www.redhill.net.au/b/b-bad.html
scroll down to the story of the VX Pro. 😀
There's actually some good stuff above that too. I particularly like the part about how they could order some mobos with any chipset they desired. The shady manufacturer would just label it with whatever chipset name.
Reply 12 of 17, by Malik
swaaye wrote:
http://www.redhill.net.au/b/b-bad.html scroll down to the story of the VX Pro. :) […]
Hehehe...very interesting article!
The VX_PRO+ definitely sounds VERY advanced!
Not only there is the word "PRO" on it, there's another "+" sign after it. As though this is the super of all chipsets. 😜
Reply 13 of 17, by swaaye
Yeah you have a collectible piece of history there. 😉
Reply 14 of 17, by retro games 100
I bought a PC Chips mobo, with the infamous VX chipset. 😖
Luckily, it didn't cost much. I didn't realise it was one of these laughed at mobos, until it arrived. The box said "PC Chips", and it was only then that I realised it might be one of these things.
Oh well. I guess I could use it for some, um, "experiments". 😉
(Photo is seller's pic.)
Reply 15 of 17, by retro games 100
I've just tested this PC-Chips VXPro+ chipset based mobo, as shown in the post directly above. The results of this test are shown below. Are they bad? (I haven't worked out what all the numbers mean in these speedsys tests yet.)
Reply 16 of 17, by elianda
here are some comparison values: http://www.dosforum.de/viewtopic.php?t=2341
Youtube Channel
Reply 17 of 17, by retro games 100
Thanks! Hehe, there are some familiar faces on that board I see! 😀 Quite a few of those tests have been done with an Intel Pentium 166 MMX. I might have to dig one of those out, and retest the PC-Chips mobo with this CPU, so that I can compare the results with the results on the dosforum website.
