First post, by retro games 100
- l33t
I'm trying to get an old mobo to work with a modern IDE hard drive. (Any "gotchas" to look out for?)
The mobo is a UMC chipset-based board, model TK8881 FA20, and can be found here -
http://www.elhvb.com/mboards/adi/tk8881/TK8881man.html
The photo shows the controller card sitting on this mobo, next to PCI slot #2 where I tried it.
Edit: I think the controller is a CSA-649U Ultra, with :
PCI Bus
• 32-bit, 33 MHz
• PCI 2.1 compliant (wonder whether my 486 mobo is OK with this?)
Power
• 3,3V Operating Voltage with 5V tolerant I/O
• ACPI: PCI Bus Power Management Spec 1.1 compliant (or this?!)
(End of Edit)
I get strange results - the BIOS behaves oddly. Each time I boot-up, the BIOS appears to behave differently - something's not right. Sometimes the card is not seen at all. Other times, the HDD attached to the controller is seen, but then the BIOS hangs. Other times, I am given the chance to hit F3 to enter the controller card's set up section, but then I can't quit this set up area because I think the BIOS has locked up again. Basically, the BIOS is unhappy about this card.
Is the problem due to a potential mismatch of PCI specification, between the mobo and the controller card? Also, I have used SeaTools for DOS to limit the HDD's storage capacity. I think this is called an "overlay" - would that confuse either the controller or the mobo's BIOS? I've tried various IDE cables - one 40 pin, two others were 80 pin. (Also, there are a couple of jumpers on the card, whose purpose is unknown to me.)
Any ideas please people? 😀
(I have got another controller card, a Promise card, but unfortunately I can't find it ATM.)
