AMI Enterprise III
First post, by GL1zdA
1.35 MiB
AMI Enterprise III motherboard
Just acquired this motherboard. I haven't tested it thoroughly, but it allows me to enter the BIOS at least. It only complains about an improper configuration for adapter in Slot 7, but think it's some old EISA config, though I can't find any EISA related settings in setup. Can anyone tell me what chipset it uses (I don't want to scratch off the AMI stickers)?
AMI Enterprise III @ stason.org
AMI Enterprise III @ stason.org (other version)
AMI Enterprise III @ ami.com
getquake.gif | InfoWorld/PC Magazine Indices
Reply 1 of 34, by Amigaz
nice mobo 😀
the eisa cards are setup thru the eisa config util made for this mobo together with the correct .cfg files for the mobo and particular eisa cards you plan to use and set the correct resources for the mobo
since this mobo has vlb slots you don't have to hunt down an obscure eisa gfx card
you're lucky the dallas chip still holds it's charge....is ut socketed?
I can help you out with different eisa config stuff for this board that might work
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 2 of 34, by Anonymous Coward
Ah, that's a good one. But it looks like somebody robbed you of all your tag RAMs, so you won't have any L2 cache until they're installed.
I can't say for certain, but your chipset is probably either OPTi or SiS.
Reply 3 of 34, by Amigaz
Looks like it needs some extra power input too? (white pwr socket left of the AT pwr sockets)
Reply 4 of 34, by GL1zdA
Amigaz wrote:
nice mobo 😀
The util is missing from the AMI website, but it seems I found the AMI EISA Configuration Utility with some 3rd party guide.
I probably use my SPEA Mercury with S3 928. Also have a Diamond Viper (Weitek P9000), but it's in 'unknown' condition.
Unfortunately it's not, so I will probably have to hack it in the future.
First I have to get some EISA cards, especially a SCSI controller.
I can't find any information, what memory should I use in this sockets neither in the manual nor on the web 🙁
AFAIK it's optional, probably useful if I run a lot of EISA cards. I still don't have any AT PSU with this P10 connector. (But except for the AMI board, I have at least 2 other mobos with the header for it).
Reply 5 of 34, by Amigaz
So far I've been lucky with the dallas chips still holding the charge on the several Eisa mobo's I have...seems like they're not drained of their juice as much on regular mobo's
Reply 6 of 34, by GL1zdA
Could list your EISA motherboards? Just curious 😀
Reply 7 of 34, by Amigaz
Two everex boards:
Forgot the model name
and this one.
http://stason.org/TULARC/pc/motherboards/E/EV … L-EV-18211.html
It also has SiS chipset like the above mobo
An Everex mobo:
http://stason.org/TULARC/pc/motherboards/E/EL … 6-SL-486VE.html
A couple of Gigabyte mobo's:
http://stason.org/TULARC/pc/motherboards/G/GI … 6-GA-486TA.html
http://stason.org/TULARC/pc/motherboar ... 486SA.html
Both of the above mobo's have SiS chipset
Also have this baby:
http://stason.org/TULARC/pc/motherboards/M/MI … EISA-50MHz.html
Have some unkknown brand baby AT Eisa mobo with a 486DX 50mhz...
Reply 8 of 34, by Anonymous Coward
I think I found the EISA CFG files you need:
ftp://ftp.bluefeathertech.com/computing/hardw … MI/Enterprise3/
There is also a user manual in that directory (EXE format). It should tell you what kind of TAGs you need. They're probably 64kx4 24pin type.
Reply 9 of 34, by GL1zdA
Unfortunately the exe contains three files with .man extension - and they're not in text format 🙁. The PDF manual from AMI's website does not even have the 3 empty cache sockets printed... There are only 8 with regular cache chips mentioned.
Reply 10 of 34, by Amigaz
http://www.fileinfo.com/extension/man
Neither winblows wordpad, notepad or MS Word can open them...so I guess you need a fancy unix text editor to open them?
Reply 11 of 34, by Anonymous Coward
I guess the best thing to try is contacting somebody else who has the same board as you and asking which tag RAMs are installed. I counted the pins in the photo, there are 22 of them. There are a couple of different densities available in that configuration, but I would guess something like Cypress Semiconductor CY7C166 (16k x 4) which was a very common one. I have an opti based VL EISA board that uses three 64kx1 chips as tag instead that is 22pin as well.
By looking at the number and arrangement of the chips on your board, I would guess you have the SiS406 EISA chipset like the rest of us.
Reply 12 of 34, by Old Thrashbarg
Two everex boards:
Is that the Everex EV-18210 in the first pic? I've been thinking about picking one of those up from Lamcast Sales on eBay, but I've seen reports of people having trouble finding an EISA config utility to work with 'em. Something about it requiring an Everex-specific one that no longer exists in any archives.
So I guess you got it working, what did you end up having to do? And also, how do you like the board in general?
Reply 13 of 34, by Amigaz
Old Thrashbarg wrote:
Two everex boards:
Yep, that's the model name 😀
I got my first 18210 from him but I accidently killed it by using an opti localbus gfx card in it by mistake since it looks exactly like an Eisa connector
The 18210 I'm using now was bought together with my Micronics board and one of the Gigabyte boards...the board came with the Eisa config stuff on floppy disks
Reply 14 of 34, by Shodan486
Hi guys,
I'm about to obtain this Everex EV 18210 board and I just want to know if the Dallas chip is socketed or not...
Second thing is that EISA cfg file, I would probably need it 😀 If there is any chance you could post a link that I could download it, or to my message box, I would be grateful... Hope it'll work.
Reply 15 of 34, by Amigaz
Shodan486 wrote:
Hi guys,
It's socketed on my board.
I'll dig up the files for you and post them here...
Reply 16 of 34, by Amigaz
Shodan486 wrote:
Hi guys,
Attached the archive with the ECU stuff
    everex2.zip
    363.81 KiB
    625 downloads
Reply 17 of 34, by Shodan486
Btw, amigaz. After browsing those pictures you posted on the net, on that Everex, what are all of those boards you have plugged in? 😀...quite a number 😀
MOBO: PVI-486SP3 Rev 1.2
CPU: POD-83
RAM: 2x16MB
VIDEO: Matrox Millenium 2MB/Voodoo2 12MB/Video Blaster VT300
AUDIO: SB Vibra16 FM
SCSI: 72GB 15k RPM HDD/YAMAHA CD-RW 16x/ZIP drive + FDD drive
NIC: 3Com Etherlink III
PSU: 230W Generic
OS: Win95 OSR2.5
Reply 18 of 34, by Amigaz
That pic is old...had an Eisa Mach32 in there
What I have in it now:
Ati Mach32 2mb DRAM VLB gfx card
Roland MPU 401 card
Gravis Ultrasound Max
Sound Blaster AWE32
3Com Eisa NIC
Some no name multi I/O ISA card
Adaptec AHA-2742 SCSI-2 Eisa card
Reply 19 of 34, by GL1zdA
Just acquired a BT-742A EISA SCSI controller (AFAIK the manufacturer is Mylex, now LSI). It also has a FDD controller.
Although LSI does have lots drivers for it, they don't have the CFG files. But it seems here are some I could use.
For the VLB VGA i'll use a SPEA Mercury (S3 928).
Now a question (possibly stupid): should I use a normal ISA FDD controller, to run the ECU for the first time, or should it be somehow possible with the (not yet configured) SCSI controller?
