No problem. AAs are these batteries :
![AA_Batteries.jpg](http://www.combatstocks.com/images/AA_Batteries.jpg)
and 2032 is this :
![cr2032_lithium_battery.jpg](http://www.proweather.net/images/miscellaneous/cr2032_lithium_battery.jpg)
A battery holder, is a small thing that contains the batteries, and lets you connect cables on it.
![bholdaa_pl.jpg](http://www.solarbotics.com/assets/images/bholdaa/bholdaa_pl.jpg)
or
![cr2032-coin-holder.jpg](http://amigakit.leamancomputing.com/catalog/images/cr2032-coin-holder.jpg)
If you do that, the batteries you are going to fit, should last for a year or more. The only problem you have then, is that you don't want the pc to recharge them. So you use a diode. A diode looks like this :
![1285250583_0.jpeg](http://www.alifragis.com.gr/products_img/1285250583_0.jpeg)
This small thing, just lets the electric current flow only on one way. So if you attach a diode on the positive pole of the battery holder, it will let the batteries power the RTC, but it will prevent the pc to recharge them. You must be careful with the diode, because it works one way. If you fit it backwards, it's going to charge the batteries, and they won't power the RTC.
