HAHHAHA you made my day... you don't know what an ARJ file is? Ok, it's like a ZIP or RAR file, only nobody uses it anymore and it's old skool like ZIP.... you need to extract the thing and it'll be in 4 separate directories... copy each directory to each floppy, files ONLY, NOT the directory with it
and like I said... you need to install CTCM first!!! what makes you think it'll come with it when I said that?
the answer is NO, it doesn't come with it, and you must install it first! you already downloaded it, so install that crap first!
