First post, by tincup
- Oldbie
Ideally you want a cpu/gpu pairing that doesn't waste the potential of either part. This is especially important when budget is a constraint since it makes no sense to overspend on one part only to have it bottlenecked by the other. Balance is also a virtue from more theoretical or aestetic standpoint as well, and in retro builds is likely the more dominant impulse.
But other than actual benchmarking are there any down-and-dirty, back-of-the-envelope rules of thumb? Given that games and applications vary considerably in their demands on either part it could only be a broad stroke estimate, but I'm curious.
Looking back at my systems where I had a gut feeling that they were fairly well balanced [in gaming] I note a rough ratio of cpu hertz [x cores if more than 1] to graphic card memory on the order of 8:1 to about 16:1
P200 Voodoo 2/12mb = 16:1
P1000 Voodoo 5/64mb = 16:1
P2400 ATI 9700pro/128mb = 18:1
AMD2400 2x256 SLI = 4:1 [this GPU-heavy rig ran 2005-10 with only minor upgrades]
AMD2400[2core] 2x256 SLI = 9:1 [above rig with faster cpu; a more typical ratio]
AMD4000[4core] 2x1gb CF = 8:1 [555BE unlocked cores/OC @ 4.05]
Oddly the P4-2400/9700pro comb felt stout at the time and was a good W98 performer to the bitter end [2005] but it's the "lightest" in ratio terms, and it bucks the general trend of narrowing ratios.
An earlier build; P200 with a Voodoo 1/4mb = 50:1 - very "light". The ratio conveys nothing of the awe my introduction to 3D was, but perhaps hints at why there was such a thirst for bigger and bigger video cards.
The first AMD rig was "all-in" in GPU terms, the idea had been to buy as much graphic power as I could afford, sacrificing CPU to meet budget. The tactic bought me 5 years of little in the way of significant upgrades. For all I know though, the cpu may have bottlenecked the SLI, but it didn't feel that way since a late game cpu upgrade didn't have a drastic effect on game performance.
What made me think of this was a Voodoo 2/12mb SLI box I'm fiddling with. Of the various slot 1 cpu's I have on hand which might be the most well suited without resorting to bench testing? Throwing out the highest/lowest results of my quick survey the numbers suggest a cpu P200-P400 range would hit the sweet spot. Hmmm...
This excersise is based purely on gut feeling and I'd be interestest to know what people who do benchmarks and take number crunching seriously think about the idea of a "rule of thumb".
