First post, by XxRetroGamerxX
Hi, I am trying to install Windows 95 since I would like a seperate computer just to use for old software and prefer that over Windows virtual machine.
After Windows 95 was finishing setup, I clicked Finish and the system rebooted. I did see the screen that reads getting ready to run Windows 95 for the first time. After about 10-20 secs the screen went black and read - while intializing device IOS: windows protection error. You need to restart your computer
I have tried several times to restart normal and safemode with the same error reoccuring.
The computer I am using has the following:
Dell optiplex GX240
Seagate 20GB Harddrive
512 MB ECC SDRAM
1.70Ghz Pentium 4 Processor
3.5" disk drive
CD-ROM
I used win95 start up disk, then fdisk to create a bootable partition. I could only make a FAT16 partition that was for about 2 GB. Then I formatted. Next since the windows 95 CD is not bootable I made a bootable CD with windows 95 on it from the original windows 95 CD through Nero. I then copied the files to the C: drive and from there went to the setup file and installed.
I dont have another 3.5" disk drive other than the one on that computer so I was not able to make a win98 start up that i believe would have CD ROM support, so that is why I used the bootable CD.
I did one time get the windows 95 setup to go to the next steps, setting up hardware, time zone and printer wizard, then had to reboot again and got the same error. Since then I tried another clean install thinking it was a software issue but I still get the same problem but have not got it back to the furthest step as the first install.
Also in bootlog.txt I noticed:
[001634A2] Loadfailed=vshare
Sorry for the long read, I just wanted to explain in detail as hoping someone who understands this better me can help figure out what I can do to fix this windows protection error.
Thanks for your time! Kevin
Reply 1 of 11, by leileilol
Retail Windows 95 (95A) doesn't support more than 500mhz, IIRC.
With that system, i'd most likely use Windows 98SE, which would work fine.
FUCK "AI"
Reply 2 of 11, by XxRetroGamerxX
Sorry forgot to mention this is I believe Windows 95B with USB support. Thanks.
Reply 3 of 11, by awergh
If your using 95B why are you making a FAT16 partition. Just use a new boot disk so you can create a FAT32 partition.
There was a patch so you could run 95 on faster cpus but I didn't think that was a problem on P4s <2Ghz
But in terms of fixing windows protection errors I can't help you that was the final motivation that forced me to finally upgrade from 98se to xp
Reply 4 of 11, by TheMAN
the patch wasn't available I don't think... in order to run Win95 on a fast system, you need OSR2.5, which is the Win95 that includes IE4 (it can be stripped out before/removed later... just google!), but it still won't work right.... 95 just doesn't work properly with newer hardware, such as USB and ACPI
you're better off running 98 SE.... there's no reason to run 95 at all on that GX240, it's too new.... I'm still wondering why you want to do that over 98!
Reply 5 of 11, by XxRetroGamerxX
Thanks everyone for the advice! I think I am going to purchase Win 98SE and see if that will work.
Reply 6 of 11, by leileilol
It should. I have a superior P4 system maining it, and it works fine.
FUCK "AI"
Reply 7 of 11, by XxRetroGamerxX
Is the Win 98SE CD bootable? As I dont currently have a win 98 boot disk which I know has CD drivers.
Reply 8 of 11, by leileilol
I know at least the OEM CDs are bootable.
You can still use a Win95 boot disk for it.
FUCK "AI"
Reply 9 of 11, by XxRetroGamerxX
Ok, thanks for the information. That would work out good since I dont have another disk drive to make the win 98 boot
Reply 10 of 11, by filipetolhuizen
Trust me, it will work great. I tested it on a P4 2.0GHz with 768MB RAM and it ran out of the box.
Reply 11 of 11, by TheMAN
yeah, retail CDs were not bootable
