First post, by MrTentacleGuy
I remember the old Sound Blasters having weird artifacts but this seems ridiculous. I've been using a SBPro compatible Crystal CS4231 until I finally picked up a SBPro 2 CT1690 for the added compatibility. Alexander's voice in King's Quest VI hisses like crazy. I had turned off the output filter with sbp-set because I heard that helped in some situations but it's still pretty distracting. I'm using amplified speakers and I had heard there was a way to turn off the onboard microphone amp but I don't think this model has that jumper. Is this as good as it gets or is there an ideal setup for clarity? The Crystal card doesn't have this problem and has a proper line out so I'll probably stick with it for a while. I was just wondering if anyone had any special solutions.
Reply 1 of 6, by MaxWar
Does the problem occurs for digital sounds in all games?
FM sound card comparison on a Grand Scale!!
The Grand OPL3 Comparison Run.
Reply 2 of 6, by MrTentacleGuy
I'll try it on some more in the morning. KQ6 is just the game I've been playing lately.
Reply 4 of 6, by MrTentacleGuy
I also have an AWE32 CT3980 but I've always heard the Sound Blasters lost SBpro compatibility after the SB16s. I never really tryed out the FM side of that one. Supposedly it's possible to mod sound cards with better components. After some more testing I suppose that's an option for the Pro.
Reply 5 of 6, by MrTentacleGuy
I don't know. Usually I post to a forum after I've been through all of the troubleshooting I'm willing to do. I was going to test some more games but I don't seem to have the time. I've already had an AWE32, a YMF719, and a Crystal card in this 486 without this problem so I'm just going to call it a problem card for now and come back to it later (it's not currently installed). I was mainly just asking if anyone knew of a quick fix as a sort of last ditch effort. Thanks to everyone for their help.
