Voodoo 1 and Voodoo 3 in same PC
Reply 20 of 40, by GreatDragon
How correctly to install Direct X and what are necessary drivers ?
Please precisely
Reply 21 of 40, by GreatDragon
Voodoo 1 working on PCI 2.2 ?
Reply 22 of 40, by elfuego
Please precisely
DirectX for voodoo 3? Ehm... The version would be DirectX 7, but you really do not want to run DirectX on V3. Really. On Voodoo 1 even less.
If you insist, install directX 8.1 or 9 and then install the voodoo 3 drivers; it should work I guess.
Reply 23 of 40, by NitroX infinity
Voodoo3 is DirectX 6. DirectX 7 is for hardware T&L which the Voodoo3 does not have.
Also, DirectX 9 is not available for any Win9.x OS. You need WinXP for that at the very least.
Reply 24 of 40, by F2bnp
That is wrong actually. DirectX 9c is available for Win98SE.
http://www.falconfly.de/directx.htm
Reply 25 of 40, by sliderider
DirectX 9.0c runtime
http://www.microsoft.com/en-us/download/detai … s.aspx?id=34429
Check the system requirements.
"Supported operating systems: Windows 2000, Windows 2000 Advanced Server, Windows 2000 Professional Edition , Windows 2000 Server, Windows 2000 Service Pack 2, Windows 2000 Service Pack 3, Windows 2000 Service Pack 4, Windows 98, Windows 98 Second Edition, Windows ME, Windows Server 2003, Windows XP, Windows XP Home Edition , Windows XP Media Center Edition, Windows XP Professional Edition, Windows XP Service Pack 1"
The last version for Windows 95 was DX 8.0, so I think that's where the confusion is coming in.
Reply 26 of 40, by Gamecollector
Yes. The first version w/o 5V cards compatibility is 2.3.
Reply 27 of 40, by NitroX infinity
Hmm, always thought #8 was the last for Win9.x. Whoops, My bad 😁
Reply 28 of 40, by RichB93
8.0a was the last for 95 iirc.
Reply 29 of 40, by GreatDragon
Voodoo 1 not working
on motherboards Shuttle AV18E and ASUS TUSL-2C
On Pentium 1 motherboard Voodoo 1 good working
Reply 30 of 40, by Borderman
I put V1 + V3 in same pc recently. Works OK except when i am running games that are using V1 i got strange distortion line coming down screen (top to bottom) every 2 sec? When i unplug short VGA cable from V3 it disappears. That only happens when V3 is in PC, when i put different 2D card besides V1 games run fine on V1...
Reply 31 of 40, by Borderman
oh i forgot, games also run fine on V3 through loop cable on V1. So really strange thing here?
Reply 32 of 40, by RogueTrip2012
GreatDragon wrote:
Voodoo 1 not working on motherboards Shuttle AV18E and ASUS TUSL-2C […]
Hate to necro this. Drop the FSB to something under 100MHz. I got the same distortion issue until I ran 66~100MHz FSB.
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>Win XP . AMD 960T . 8GB . Q.K2200. SB X-Fi . 512GB SSD . 2TB HDD
> Win XI . i7 12700k . 96GB . RTX4070TI . 512GB NVME
Reply 33 of 40, by Maraakate
The Build engine games like Blood and Shadow Warrior that have 3DFX versions are really picky about running on anything non-V1 or V2. I have gotten them to work with environment variable tweaking on later 3DFX hardware, but I assume it probably runs better on the original intended card.
Reply 34 of 40, by fillosaurus
My personal experience: Shadow Warrior works with a single Voodoo 2, never managed to run it with 2xV2 SLI.
Y2K box: AMD Athlon K75 (second generation slot A)@700, ASUS K7M motherboard, 256 MB SDRAM, ATI Radeon 7500+2xVoodoo2 in SLI, SB Live! 5.1, VIA USB 2.0 PCI card, 40 GB Seagate HDD.
WIP: external midi module based on NEC wavetable (Yamaha clone)
Reply 35 of 40, by filipetolhuizen
I could run Shadow Warrior on V2 SLI back when I had a Pentium II and I still run it on my B&W PowerMac.
Reply 36 of 40, by dario82
i have same problem when i try launch some games with my voodoo3 + voodoo 1 in my pc, screamer2 or tombraider... my motherboard is a Asus CUV4X
can you help me please?
i have try also two games with voodoo1 but the texture are bad or black...
Reply 37 of 40, by subhuman@xgtx
dario82 wrote:
i have same problem when i try launch some games with my voodoo3 + voodoo 1 in my pc, screamer2 or tombraider... my motherboard […]
Decrease FSB to 66mhz
Decrease FSB to 66Mhz
Bear in mind I usually post to the forums using my old systems.
Reply 38 of 40, by dario82
from the bios right?... i will try, but my pentium 3 can work always at 800 mhz?
Reply 39 of 40, by dr.zeissler
I installed a V3000-AGP and a MiroHighScore3D (V1) in the same PC.
I am running Win95b and the DX61 Drivers for the Voodoo3.
The Voodoo1 Driver is not installed at Win95b.
How can I manage to run ShadowWarrior, Screamer2, and other DosGildeGames ?
What Files do I need, do I have to create a Batchfile in order to run this and what should I write in it ?
Thx
doc
