First post, by TheLazy1
So far I've had no luck, at least with one combination of ODI? driver and packet driver shim.
MTCP Will recognize that a packet driver is installed but it just times out on everything.
Sure, I could use the well supported 3c905 cards I have lying around but since I'm going diskless the added bandwidth of gigabit is going to be much appreciated.
What does this have to do with dos packet drivers?
My setup ideally would be:
1) Boot win98 using memdisk using iPXE.
2) Do stuff
3) When done stuff exit to dos mode
4) Rsync the memdisk back to the PC hosting the image
5) Update win98 memdisk
6) Goto 1
Unfortunately without a packet driver to run rsync this whole setup is pretty useless.
Edit:
Tried with the 8169 NDIS driver, tried WATTCP and still no luck.
