First post, by thegardentool
Well I got some time to start going through some of a larger lot I picked up a couple weeks ago. I knew a few of the motherboards had busted barrel batteries. I was going to use them to brush up on my soldering and desoldering skills, as well as use them to learn how to clean up battery acid.
Unfortunately one of the boards I wanted to use has some gouges underneath that cut quite a few traces. It looks like damage from hitting standoffs but I suppose there really is no telling. It's a Gigabyte GA-586HX that I was going to mate up with an MMX233. All the parts I was using to test it with did work on a different board, an ASUS VX97, so I could rule those out. The board received power, keyboard lights came on and the CPU fan started, but no POST and nothing when I hooked up a case speaker either. I suppose I'll try my hand at attempting to repair the traces and if it doesn't work then just use the VX97 instead for a Socket 7 build.
This got me wondering, what do you guys do with hardware that is broken or beyond your repair skills?
Main: 7800X3D | X670e | 3090 | 4k144hz
Retro: Kind of together: P3 | ASUS P3B-F | Canopus Spectra 2500 | Canopus Pure3D II SLI | (sometimes a Voodoo 5 AGP) | SoundBlaster AWE32|
