First post, by FeedingDragon
- Oldbie
Ok, not having any luck finding one with web searches and eBay. So I thought I'd ask here 😀 I used to have a small metal case, it had room for 4 drives. It was designed to house SCSI devices including Tape backup and/or CD-ROM drives (had removable panels.) It had no electronics except for a small power supply that did not need a motherboard to power on (just hit the switch like old computers.) There was a small opening in the back for running the SCSI cable. What I want is to house a 3.5" and a 5.25" floppy drive with my Kyroflux board. Instead of running a SCSI cable, I'll run a USB cable. All I'm finding are micro-cases that are rather more expensive that I think something like this should cost. Or things that are much larger than I would like. In both cases they come with power supplies that I would have to hack to get to work. Any help in finding these would be appreciated. Though I won't be doing anything until after the move, I'd sort of like to have sources lined up.
Thank you 😀
Feeding Dragon
