First post, by spaceman73
Hi Everyone,
1st post on Vogons, but have been reading bits and pieces and have found valuable help in old thread when setting up my Pentium Dos Time Machine with CF card a few months ago.
Now I am trying to get a recently purchased Tandy 1000SX to run with a XT-CF card and run all the early games which took advantage of the TCGA and 3 voice sound on that system. I am trying to set it up in a similar way to my Pentium machine, with all the games for it on a CF card. I had some problem originally with the CF card and the XT-CF card, but most of that seems resolved now.
However, I am left with a small 32MB hard drive (out of my 256MB CF card). This is the only way I could get it to run and if I understand well, it is due to the Tandy DOS 3.2 disk I am using to set/boot. I have tried setting the card with extended and logical partition all of 32 MB, but that Tandy didn't seem to see them (even if my Pentium did as it was setup there). Now if I could have a way of using a full 256MB or 512MB CF card divided in multiple 32MB drive under Dos 3.2, I would be happy with that. Is it possible?
Or I have read that Compaq Dos 3.31 would be able to see a bigger drive (up to 2GB?). I have the means to transfer that to Floppies and could run the Boot disk on my Tandy and set things up there, would that be a better option? Would I lose TCGA or 3 voice sound by doing something like that? Any other negative/positive?
I suspect getting the games on the CF card would require 512MB if possible, but can be cut down to 256MB if needed I guess. But only one 32MB drive just won't do it... I am a bit loss at how to set this up in the best way, so any help would be appreciated.
Thanks
