Ps/2 on AT-Systems
First post, by brostenen
Is there a pci/isa-card with Ps/2 input, that can be mounted in an at-system?
Reply 2 of 33, by soviet conscript
I'm thinking hes wanting one so he can use a modern mouse just like most of use would like.
unfortunately although I have read people claiming that ISA ps/2 cards exist there extremely rare if they do. I've never seen one. I think there was a project at one point to develop one, honestly they came up with the XTIDE so I don't see why a ISA card that sported a PS/2 adapter is so hard to make, then again I'm no computer engineer.
there are PCI PS/2 port cards but the first PC's to use PCI were late model 486 machines so.....
some OEM systems had PS/2 ports built in. I had a Wang 386 machine that had built in PS/2 ports for a keyboard and mouse.
Reply 3 of 33, by RacoonRider
It's easier to get an OEM PC with PS/2 than to try to get PS/2 on a computer that does not have it already. Many have tried, as far as I know, all have failed.
Reply 4 of 33, by brostenen
Found information on them cards, on the net. 😜
They are called "Microsoft InPort".
And yes, they are expensive, as they are ISA cards.
Reply 5 of 33, by vetz
That is a proprietary Microsoft system and not PS/2 compatible.
There have been loads of threads about this subject before here on Vogons. I suggest you search up and read why its not that easy.
Reply 6 of 33, by armankordi
why don't you get a cheap serial>PS/2 connector? I did this with my 486DX system with no PS/2
http://tinyurl.com/loqadnt
IBM PS/2 8573-121 386-20 DOS6.2/W3.1
IBM PS/2 8570-E61 386-16 W95
IBM PS/2 8580-071 386-16 (486DX-33 reply) OS/2 warp
486DX/2 - 66/32mb ram/256k cache/504mb hdd/cdrom/awe32/DOS6.2/WFW3.11
K6/2 - 350/128mb ram/512k cache/4.3gb hdd/cdr/sblive/w98
Reply 9 of 33, by soviet conscript
for me the main draw of a ps/2 port on an old machine would be to use some kind of laser mouse and not a ball mouse. There really not much difference between using a ball serial and ball ps/2 mouse. sure ps/2 mice are way more common but you can still find serial mice at thrifts for 1 or 2 dollars, there not very rare.
problem is there's not really any laser mice that work via the serial port, I don't think it supplies enough power so even with an adapter I don't think it would work. And if there are early laser mice that may work with a serial port I'm guessing there so buggy and/or rare may as well go with a ball mouse.
Reply 10 of 33, by brostenen
I find it hard to search for something specific on forums, must be me.
Anyway...
Did not know that it was a non-Ps/2 mouse in Ps/2 disguise.
Thanks for the information. 😀
Reply 11 of 33, by brostenen
My old parents have this optical mouse, from the 80's.
Serial and Unisys branded. Only problem is, that it need this special mousepad, made from metal.
I have seen one on youtube, were (I think) it is "lazy gamer" that reviews it.
Only difference is that the one I used in my childhood, did not have pass-through, only regulair serial.
I have this Serial to Ps/2 converter, and I know those dual mode mouse's are rare.
Reply 12 of 33, by brostenen
Would something like this work in a P133, with PCI slots?
http://www.ebay.com/itm/PCI-2port-USB-2-0-2po … =item4166114122
As the board have both ISA and PCI slots, I really do not need that ISA card wich do not excist anyway.
Reply 13 of 33, by smeezekitty
this was literaly just discussed in another thread.
Those kind of cards are USB cards with a built in USB to PS/2 converter so it will only work
in Windows 98+ unless you have USB aware BIOS
Reply 14 of 33, by brostenen
How about this little item? http://dk.mouser.com/ProductDetail/FTDI/DB9-U … tgmA/N4WlteGg==
Would that be usefull, if soldered into and replacing the com port, then using a driver (serial mouse-driver or usb-driver)
Reply 15 of 33, by NJRoadfan
Pentium class AT boards usually have support for a PS/2 mouse, just need the header cable.
Reply 16 of 33, by brostenen
Sadly, mine does not have it. The board is a QDI P5I437P4/FMB from around 1996 or 1997.
If that serial/usb thing indeed does support a mouse driver in Dos, then it could be good.
As I recall, there was a converter, wich could convert a Ps/2 keyboard into a DIN type.
Then both mouse and keyboards would not be any issue any longer.
Reply 17 of 33, by Maeslin
That serial-usb piece wouldn't do. It's a USB device, not a usb host. It's meant to be installed in devices currently using a serial port (external modems, old graphic tablets, etc.), not on the 'computer' side.
Reply 18 of 33, by feipoa
I few minutes in google should provide plenty of answers. This topic has been beaten to death.
1)
PCI PS/2 cards are really USB cards with a PS/2 converter on it. You need to install the USB drivers for this to work. It will not work out-of-the-box with DOS. You will need to figure out how to get DOS to function with it, if it is even possible.
2)
There are dual-function PS/2 and serial protocol mice. The adapter used just swaps some pins around. The mice itself must be dual-function. The ones I've seen have been trackball mice.
3)
There exist protocol converters for translating PS/2 mice signals into serial signals which should work with most, or all, PS/2 mice. Some companies make them, such as Raritan (sp?) or Vetra systems, http://www.vetra.com/327text.html , however I found the conversion quality to be rather poor, resulting in a noticeable lagging or jumpy mouse at resolutions above 640x480. They are also costly, $60+. A user here made his own protocol converter, which you will need to package on your own. See this thread, PS/2 to Serial Mouse protocol converter
4)
Some serial and PS/2 KVM switches have protocol converters built-in. Cybex Switchview is one such unit. But again, I was not pleased with the tracking quality after conversion. Or was it the Belkin Omni View SE that had a working converter? I forget which of the two units it was, but one if them did not work at all, and the other I was not happy with the conversion quality.
5)
I have not played with the Microsoft bus Mouse 8-bit ISA card. You need a proprietary Microsoft bus mouse to use that. There may be some bus mouse converters to PS/2? PS/2 mice will not work on that port directly.
6)
I prefer the approach of modifying your computer's keyboard controller to work with a PS/2 mouse. It is a bit more involved, but there is no conversion quality issues with the mouse tracking. Refer to this link, Native PS/2 mouse implementation for 386/486 boards using the keyboard controller . To-date, only AWARD-based BIOSes seem to work with this modification.
Reply 19 of 33, by brostenen
feipoa wrote:
I few minutes in google should provide plenty of answers. This topic has been beaten to death. […]
1)
2)
3)
4)
5)
6)
I know it has been beaten to death. Yet... If you read this thread, I have found that usb to db9 converter wich can be soldered directly on to the motherboard. I am now asking if that solution would be usefull.
I am thinking this: As they are talking about that product, as a cheap usb-upgrade for older pc's and products, as it contains a usb to serial converter chip, you might be able to use a usb-mouse-driver or a serial-mouse-driver, in order to make to communication between onboard serial and external usb.
Perhaps mighty mouse driver or the ohci/uhci (that symantech mouse something driver) would do the trick at getting a mouse to work.
Thereby skipping the Ps/2 portion of this issue completely, and sequring 486/early pentiums for future usage.
