Reply 221 of 334, by Mau1wurf1977
Aww they look awesome 😀 Well done!
My YouTube channel
Reply 223 of 334, by Mau1wurf1977
I must say, although they aren't for me, there is something about having a few ready-to-go 486 PCs at home 😀
My YouTube channel
Reply 225 of 334, by Artex
feipoa wrote:
That is awesome! Feel like posting your templates?
Sure - here's a zip of them. A few variations on the Cyrix 5x86, the AMD Am5x86 and a Intel DX4 badge. These were a (VERY) rough, quick mockup in Photoshop and they were somewhat pixelated at the original size. However, when shrunk to 25mm x 25mm, it's not as evident.
    Case Badges.zip
    21.54 KiB
    91 downloads
Reply 226 of 334, by dirkmirk
Thanks guys for the last couple of pages lots of good info!
So its safe to assume the AM5X86@160 edges the Cyrix 5x86@120 for gaming? I found it suprising that the AMD scored higher than the Cyrix in Quake I would think its also safe to assume the AMD would score better for most games in that case.
Reply 228 of 334, by feipoa
With both run on the Biostar board, X5-160 15.1 fps in Quake (but noted not stable). Cyrix 5x86-120 14.8 fps in Quake (but stable?)
Artex, perhaps you could run the Cyrix 5x86-120 in your VLB board to compare it with the X5-160?
Reply 229 of 334, by Artex
I can try this if I have time.
Now that these two builds are set up, I think I'm going to start adding sound cards, network cards, etc to get them 'more' set up. I also want to get that Saturn board up and running - I'd hate to have it sit there not being used. I'll probably throw my DX4 WB in there..
I need to track down another power supply as well - not sure I want to get a 'new' AT power supply or try to find an ATX with -5V and use a converter.
Reply 231 of 334, by Artex
feipoa wrote:
What were your symptoms of instability with the X5-160 in the Biostar board?
I was able to get it working (and stable) at 133Mhz and 160Mhz.
Reply 233 of 334, by Artex
feipoa wrote:
Sorry, got lost in the posts. Do you have a high resolution image of the Saturn II board?
No worries! This thread has become quite massive. I'll grab a new picture for you tonight with a better camera.
EDIT: Picture attached
    3.02 MiB
    No downloads
Reply 234 of 334, by feipoa
MX8315 for generating the FSB. This chip will generate 20, 25, 33, 40, 50, 60, and 66 MHz FSBs from your 14.31818 MHz crystal. There are 3 inputs on the MX8315 which select the FSB. I suspect that if you solder in the missing jumper header, JP19, that you should have access to the full spectrum of FSBs.
Reply 235 of 334, by Artex
So... one of these puppies?
Reply 236 of 334, by feipoa
That's right. And you can use one of these puppies to suck out the old solder.
17.2 KiB
Reply 237 of 334, by Artex
Cool - I have one of those already. I'll see if I can source that header and see what I can do.
Reply 238 of 334, by feipoa
You could desolder that header from a dead motherboard. Even if you have a 4+ pin header, they are meant to snap to reduce in size.
Reply 239 of 334, by Artex
Good idea. I'll see what I can find. I'm kind of a novice at soldering so it makes me a little nervous. I've really only de-soldered to remove barrel batteries.
