Reply 180 of 328, by Liqu1d82
Always the same build I'm testing these days: ASUS CUV4X-D + 2xPIII 800EB + 2x512MB PC133 ECC
1M @Windows 2000:
And these are the results from my mothership, CPU @stock and overclocked @3300:
ASUS P5B + E4500 @2200mhz + 2x2GB DDR2 800mhz
ASUS P5B + E4500 @3300mhz + 2x2GB DDR2 750mhz
Without change something sleeps inside us, and seldom awakens. The sleeper must awaken.
http://liqu1d82.tumblr.com [My Tumblr] // https://twitter.com/Liqu1d82 [My Twitter]
Reply 181 of 328, by sunaiac
Moved to a new CPU :
core i7 950 @ 3.83GHz: 10.873s
becomes :
core i7 980X @ 4.13GHz: 10.000s (no kiddin' 😀 )
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 182 of 328, by noshutdown
videocard drivers can have much impact on superpi results of slow cpus!
platform:
cyrix 6x86-133
mvp3 board with 2mb cache
256mb pc66 sdram
geforce2ultra or rage128
windows2000
without video driver(unknown vga), using rage128 driver or nvidia 8.05 driver(last version of the pre-10 series): around 20:50 as already posted.
using nvidia 30.82 driver: around 21:50
results are reproducible.
thats a whole minute or 5% difference, which can't be neglected. however the 30.82 driver allows 3dmark01 to run on this cpu while 8.05 simply hangs up. both drivers fail with any opengl game on this cpu though.
Reply 183 of 328, by Liqu1d82
Intel Core2Duo E8500 overclocked @3800mhz (400x9,5) + ASUS P5B + 4GB DDR2 Geil CAS4 (OS: Windows XP)
Reply 184 of 328, by BSA Starfire
P4 northwood 2.6ghz HT, 800fsb, 512mb DDR400, XP SP2.
file.php?mode=view&id=15268&sid=d6188e194af63b5159c3a2d9f207d9d7
    124.07 KiB
    No downloads
Reply 185 of 328, by foey
P4 Prescott 3.0Ghz HT, 800FSB, 1Gb DDR400 Dual Channel, 5950Ultra, XP SP3
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Reply 186 of 328, by BSA Starfire
file.php?mode=view&id=15456&sid=f543eacc0f534d72b44916b0385012bb
Celeron D 360 (cedar mill, 3.46Ghz, 512k cache, D0 stepping). 0m46.816s
    214.81 KiB
    No downloads
Reply 187 of 328, by LunarG
No screenshot at the moment, but I'll copy it across tomorrow and upload it. With Intel DX4 100MHz, my 486 has now done SuperPi @ 1M in 1 hour, 1 minute and 15 seconds, which is a whopping 16 minutes faster than the Cyrix 486DX4. A pretty good improvement in my opinion 😀
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
Reply 188 of 328, by foey
CPU Pentium III Coppermine 1Ghz, SL4MF, 133, 256k @ 1063mhz (143 FSB)
Motherboard MSI MS-6309 Via133 Pro Motherboard
RAM 384mb PC133 CAS3 Ram
OS Windows 2000, SP4
2m 18.679sec
Reply 189 of 328, by BSA Starfire
file.php?mode=view&id=15490&sid=40ca68fca133e0b7c70f89fd41e485d3
Sempron 2800+ 1m00.750s
    162.58 KiB
    No downloads
Reply 190 of 328, by Mau1wurf1977
A quick question regarding this benchmark.
I have a motherboard, it's an AOpen AX59 Pro. I did my benchmark runs for my motherboard reviews and had no issues with a MMX 233. However with an AMD K6-2+ 550 I'm getting errors (not exact round and not convergent in sqr05).
It completes all other benchmarks without any issues. I tried various memory modules and relaxed times as well as feeding a little bit more voltage (2.2 V instead of 2.0 V required).
Any ideas?
PS: I use the exact same CPU. memory and graphics card as in other systems. Also the same OS, benchmarks and everything else.
My YouTube channel
Reply 191 of 328, by joacim
Motherboard: Asus CUSL2
RAM: 512MB PC133 (256+128+128 MB)
OS: Windows Me
Got a new CPU two weeks ago to see if the CPU was the cause of the interference issues that I've been having (it wasn't).
Pentium III 933:
Pentium III 1000:
The difference in performance isn't noticeable to me, but the upgrade was cheaper than a pint of beer.
Reply 192 of 328, by Skyscraper
Athlon 64 FX55
Reply 193 of 328, by JayCeeBee64
Rank Retired
Retired
Pentium 166MMX, Asus TX97-XE (Socket 7, Intel 430TX, 512kb secondary cache), 64mb EDO ram, Matrox Millennium 4mb PCI, Windows 95A
Pentium 4 2.4GHz Northwood, Soyo P4I-845PE (Socket 478, Intel 845PE), 512mb DDR-333 ram, NVIDIA GeForce 4 Ti 4200 128mb AGP, Windows 98SE
Core i5-3350p, MSI Z77A-G43 (MS-7758, LGA1155, Intel Z77), 8gb DDR3-800 ram, NVIDIA GeForce GT 640 2gb PCIe, Windows 7 Ultimate SP1 64-bit
Ooohh, the pain......
Reply 194 of 328, by Skyscraper
SuperPi 1M
Pentium D 950@4800 MHz
Reply 195 of 328, by Skyscraper
Athlon X2 6000+ (K8, 1MB, 0.09 micron) @ 3450 SuperPi 1M
Reply 196 of 328, by Skyscraper
Pentium Dual Core E2160 1.8@3.6 GHz. SuperPi 1M
Reply 197 of 328, by lazibayer
CPU: K6-3+450 ACZ
Mobo: P5A-B
RAM: 256MB PC133 2-2-2
OS: XP SP3
124x5=620MHz, with onboard cache disabled:
221.46 KiB
No downloads
112x5.5=616MHz, with onboard cache enabled:
222.33 KiB
No downloads
112x5.5=616MHz, with onboard cache disabled:
221.76 KiB
No downloads
Each condition has been tested 3~4 times and only the best score is posted. 124x5 is a hair faster than 112x5.5 and onboard cache can boost the latter by a couple of seconds.
Reply 198 of 328, by lazibayer
CPU: Pentium Overdrive 83MHz at 40x2.5=100MHz
Mobo: FIC 486-GAC-2
L2-cache: 0KB
RAM: 64MB 60ns FPM
OS: XP SP3
It's really hard to squeeze a lot of info on a 640x480 desktop!
91.25 KiB
Reply 199 of 328, by smeezekitty
lazibayer wrote:
CPU: Pentium Overdrive 83MHz at 40x2.5=100MHz Mobo: FIC 486-GAC-2 RAM: 64MB 60ns FPM OS: XP SP3 […]
Mobo: FIC 486-GAC-2
RAM: 64MB 60ns FPM
OS: XP SP3
XP on a 83MHz POD with 64 MB of RAM? Goodness that must be bloody slow
