First post, by brad1982_5
Hi there Got a Diamond Flower (DFI) 486-25/33/50 ISA motherboard, all works great! Massive retro AT motherboard in it's original DFI case. Sorted out the clock issue
It originally came with a 486sx 25Mhz processor so I have removed it and put in a 486dx 33Mhz processor. It starts up fine and shows up as a 486dx 25Mhz as expected. But I am having trouble trying to change the speed of the CPU to 33 Mhz. My motherboard looks exactly like this diagram.
http://open-sez.me/th99/m/C-D/31405.htm This is the closest I can find as this one is a 486SX-16/20/25UCE
When I set J7 can set the speed between 12.5 MHz and 25 MHz and that's it'. I've played with J4 and J6 despite them being factory jumpers it made no difference.
All other jumpers are for the cache memory which are set correctly at 128KB cache and the other one for the colour/mono monitor selection, the only one I have not touched is J19 but I doubt it's that.
I just wondering if I'm doing something wrong or something i'm just not seeing. Any ideas?
Reply 1 of 6, by meljor
found this, don`t know if it helps any....click on the board and you see all the jumper settings.
http://stason.org/TULARC/pc/motherboards/m486 … ml#.U9znA_l_u30
Reply 2 of 6, by brad1982_5
Thank you for looking 😀 however it's already the same source that I've already presented.
The board must be hardwired to a 25 MHz front side bus and can not be changed which would be strange if it states on the board that it can do 25/33/50. I suppose it's a OEM motherboard that's provided. Oh well 😖
Reply 3 of 6, by JaNoZ
Where is the clock generator, try to find its datsheet, and find the hardwires to be modified.
Reply 4 of 6, by brad1982_5
Not got a clue, will have a look for it, many thanks! 😀
Reply 5 of 6, by brad1982_5
I think I've found it.
It's a square silver tin that looks like it's removable it's got a cable tie around it and it shows 25.000 MHz on it. So I assume to change the FSB of the board you will have to change that part.
It's not worth investigating further, cheers for the info anyway 😀
Reply 6 of 6, by JaNoZ
So you have to change the osillator to up the fsb
