Hi all. Apologies for waking up an old thread but I thought I'd add to this thread my recent experience with getting a 286 on the internet with Arachne. My 286 system specs are as follows:
ZENITH data systems Z-286LP Plus
286/12 cpu
256k vga, IDE, FDD, two com ports and one parallel port
8 megs of ram.
49 megs usable on 52 meg hdd on internal controller
3.5" 1.44 meg fdd on internal controller
IBM P97 18" monitor
Genius Easy Track on com2
Generic AT enhance keyboard
Parallel port LS120 drive
Sound Blaster CT 1740 sound card
GE2000 (KYE)Genius Lan nic with rj45 and bnc connectors. Set to auto
detect media type.
Software installed:
MS Dos 5a
Nic packet driver
Driver for the LS120
XTree Gold
GeoWorks Ensemble 2.0
Arachne 1.97;GPL.286-
mTCP suite
Norton SI
NeoPaint
No Windows or Linux required or needed 😉
All I did was fit a nic, load a packet driver, then install install Arachne 1.97;GPL.286-. Ran though the set up routine manually setting addresses, gateway etc, Worked right off the bat. Connected to the router through an old hub I had laying about.
Never really thought I'd ever see a 286 on the internet with a graphical web browser myself. Might encourage others to give it a shot for the hell of it.
