First post, by bjwil1991
- l33t
Hello everybody:
Currently, I'm running an older PC that has only IDE support and disabled the support in order to do tests to see if my PC can see my LG SATA DVD Writer. The card I'm using is a VIA VT6421a SATA RAID with the Memphis BIOS for booting my 60GB Hitachi 2.5" Hard Drive with MS-DOS, which works without issues, but the DVD Writer cannot be seen on the system, no matter what drivers I try to use.
The following drivers are the ones I'm trying out:
AHCI.sysUDVD2.sysUIDE.sys (XMS init error)GCDROM.SYSXGCDROM.SYS
What seems to be the problem? Am I doing configurations wrong for each driver?
