Reply 580 of 31248, by PhilsComputerLab
Played Unreal on a Pentium III 1.1 GHz setup with a Voodoo 5 5500 AGP and played around with the 3dfx driver options. Quite a few settings you can change to make glide games look nicer. Compared the 22 bit and 32 bit options for glide games and did a game play capture in 32 bit. But will settle for 22 bit going forward as 32 bit costs quite a bit of performance.
AA not worth it IMO.
Must say that Unreal looks gorgeous and is really fun to play. Lots of hunting around looking for the way forward...
YouTube, Facebook, Website
Reply 581 of 31248, by elianda
I tested a bunch of small speakers as preparation for the Long Night of Computer Games in Leipzig (25th of April).
Youtube Channel
Reply 582 of 31248, by Skyscraper
I am sorting through my PCI-E DX9 video cards for some benchmarking of the game FEAR.
So far I have found Geforce 6800 GT/Ultra, 7800 GTX, 7800 GTX 512, 7900 GTX, 7950 GX2, Radeon X850XT(X), X1950 Pro, X1950 Pro 512, and X1950XTX.
I have also found slower cards like the Radeon X600 and such but I do not think I will bother with those.
Reply 583 of 31248, by Arctic
I am fixing my other Asus PC.
It has an A7V333 Rev 2.0 and an Athlon XP 2800+ Barton core.
It´s my fastest AGP 3.3v system
Reply 584 of 31248, by pewpewpew
file.php?id=16737
file.php?id=16738
A bit of the less ordinary today. This is the original production OLPC XO-1 of 2007. Found it last month in a local thrift, and had just enough time to clean & charge before giving it to a friend at holiday coffee. Now it's back for a reflash and to have the RTC battery checked.
There was no corrosion on the battery, which was a problem with these, and the onboard diagnostics show all is good. Updated the firmware to latest because there's been a lot of fixes and possibly improved diagnostics. Reinstalled the old build of RedHat/Sugar to keep it period otherwise.
It's utterly charming. It's like a kitten - you just can't help but keep picking it up to play.
Reply 586 of 31248, by Caluser2000
Set up an IRC client on my OS/2 v3 box, a 486dx2/66 system and gas bagged with the vcf crowd for a bit.
Reply 587 of 31248, by Godlike
Hi Mau1wurf1977, I like you youtube builds!
Today I received parcel with fully functional vintage system for cheap as 8usd;) Inside where Socket 7 Intel i430vx, Pentium 133Mhz, ATI 3D Rage II, Analog devices soundport ISA, some simms and sdrams. I bougth it for a nice 95 era pc case for my HOT 569 build, but unfortunately is too small;((( well, that's must be advantage to find better one, ha
ASUS P2B-F, PII 450Mhz, 128MB-SDR, 3Dfx Diamond Monster 3D II SLI, Matrox Millennium II AGP, Diamond Monster Sound MX300
Reply 588 of 31248, by Arctic
I am still trying to get my OCZ NIA to work.
Reply 589 of 31248, by PhilsComputerLab
Changed my online identity 😀
That's a nice system and will play a ton of DOS as well as early Windows games.
I played around with EZ-Drive 9.03W (Dynamic Drive Overlay), the Western Digital Edition. Got an old Acer 486 OEM motherboard which has a 504 MiB BIOS limit and that was the ideal candidate for testing. I produced a video which I will link in the thread in Release Announcements.
Reply 590 of 31248, by Godlike
philscomputerlab wrote:
Changed my online identity :) […]
You are good in camouflage same as hardware, I didn't recognize you heh;)
Very interesting with exceeding BIOS limitation. Please PM me when new vid comes, you always served something interesting! If you wish you can see my very first " Big MS-DOS question" post
You will see there full specs of my 586 class pc system. Maybe you could help with some questions. On the other hand, nice to meet you 😀
Reply 591 of 31248, by kuparikettu
I replaced case fan in my Industrial PC Pentium MMX 233 with a bit more modern and quieter one. Also received today the extension cable for my midi daughterboard, so now I finally have a well working system with both MT-32 (connected to AWE64 Gold IRQ 9) and TopWave 32 (connected to Audician 32+, IRQ 7) 😀
Reply 592 of 31248, by Godlike
Anyone know SiS 530 Chipset is good? I can get form friend of mine Asus P5S-B with AMD K6 but never test it and not sure about this one, enyone had this board? what do you think about it?
Reply 593 of 31248, by Robin4
Currently iam beeing busy with my 2000-2004 computer.. I already got the boards but iam decide which bios iam going install in these boards.. More to come.. The rest would be a surprise. 😊
Reply 594 of 31248, by AlphaWing
Put a Swifttech MX370, the best socket 370\A heatsink on one of my Tualatin boards.
It can run passive now, the pins on this things are in the style of a screw and give it a large amount of surface area.
http://www.frostytech.com/articleview.cfm?articleID=884
Review of it with pictures, since I'm to lazy to take some.
Reply 595 of 31248, by PhilsComputerLab
Putting Seagate's DiscWizard Starter Edition 10.45 through its paces on my Acer 486. Works great but some compatibility issues. Capturing footage for a video and a proper write up.
Also when I installed Windows 98 SE it told me it needed at least a 66 MHz processor 🤣
So the 486DX-33 didn't cut it, an opportunity to test my IntelDX4 Overdrive which works fine and let me install Windows 98 SE. Installation is still going, will be interesting to see how it performs with 32 MB of RAM 😊
Reply 596 of 31248, by King_Corduroy
Scrubbed and cleaned my Sega Genesis. This was a thrift store find and was extremely grubby as you can probably tell from this photo.
Here's how I found it, completely coated in filth:
And here it is after a little bit of scrubbing and wiping on some Pledge to give it a bit more of a deep black colour:
Other than that I'm just waiting for the CF to IDE adapter to replace the bad HDD in my Packard Bell 812CD. Things are a bit boring on the retro front.
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 597 of 31248, by brostenen
Did a test setup, using my Epox MVP3-C board.
K6-2-500 and 128 megabyte of ram.
SB16 Vibra (OPL-Edition) and Matrox G400 AGP (Dual-head).
Got UT99 running at 1024x768x32 Lagfree.
Got NFS Porche running at 800x600 all other settings low except viewdistance were set to max.
3D-Mark99: 2756 in 3d-mark and 5830 cpu-mark.
Installed a Realtek NIC and thinking about what case to put it all in.
Reply 598 of 31248, by Darkman
setting up a 750GB Hitachi Ultrastar SATA HDD in the HP XW4400 machine , to replace the 320GB IDE drive it was using,
considering the rest of the machine , using an IDE hard drive was a bit archaic , and the extra space is welcome.
Reply 599 of 31248, by PeterLI
I played Civilization and Wings of Fury on my 286 today / yesterday. I have to move my P3 upstairs. The basement is too cold now. 🤣
