Reply 740 of 27705, by QBiN
- Oldbie
wrote:Well perhaps not in a system I will use, probably only for benching so I do not really know if I will bother to recap it.
For use other than benching I prefer the 8800 GTS 512, I do not really like crippled GPUs 😉
I would encourage you to recap. Running with bad or out of spec capacitors could lead to a short or leakage current affecting the motherboard or other components. If the testbed is worth safe-guarding, it'd be worth the effort to recap or get a better video card.
