First post, by badmojo
Take for example this fine card. It has the solder pads for an OPL3, they have traces, and I know that this card's chipset supports a real OPL3. What would happen if I soldered one on?? Has anyone ever tried?
Reply 1 of 6, by smeezekitty
The thing I would be worried about is it may not have the necessary support components. Notice all the resistor and capacitor pads without a part soldered?
Reply 2 of 6, by Great Hierophant
You would need both a YMF-262 and a YAC-512 and need to figure out what passive components you would need, if any. Also, the ESS emulates an OPL3, so there would have to be a way to disable the chip's OPL3 emulation. Of course, the board may be an earlier design that used the Yamaha chips and a central chip that was not capable of OPL3 emulation, and the newer chip was able to be shoehorned into the existing design without having to lay out a new PCB.
Reply 3 of 6, by RacoonRider
badmojo,
It looks like it might work, make sure to let us know if you give it a try!
They most probably support MC3403 amplifier also not included here. Not something I would miss on a sound card 🤣
http://www.st.com/web/en/resource/technical/d … /CD00000473.pdf
Reply 5 of 6, by alexanrs
The best bet would be finding a version of the card with the Yamaha chips and see what else is also there
Reply 6 of 6, by badmojo
Anonymous Coward wrote:
Ah, this card is brought to us by the same fine people who made the "Audician".
The Yamaha chipset thing? This particular Audiodrive is a very solid implementation of the ESS1688 chipset; it's responsible for the DOS duties on my PIII machine and I think it rocks. Beautiful sounding SB Pro emulation, bug free wave table header and ESS FM which I think sounds great. So I won't be experimenting on this particular card, but you often see an empty space for an OPL on the clones.
Thanks for the responses, maybe I'll just suck it and see one day for a laugh.
