First post, by Turboman
- Member
Hey guys, I need some assistance for MFM hard drives. I have a few drives that I am trying to test and it seems no matter what I do I can't get a response from the drives.
I have an IBM 5160 and I have a few controller cards. I got to the point where I no longer get the 1701 error but I can't seem to find debug on this floppy that I have. I also tried this on a 486 motherboard but can't get it to work. These are the hard drives that I have, ST-125, ST-412, ST-4038, ST-251 and Miniscribe 3438.
These are the cards that I have, WD10025-WX2, IBM 1501492 IBM5004403, SMS FAB 0005476 Rev B, WDXT-GEN2, WDXT-GEN2-PLUS, WD1004A-WX1, and Seagate ST-11m
With the ST-11M it boots before the floppy does with the bios 1.7 and says Hard Drive 1 detected drive 1 not initialized and asks me if I would like to run the initialization procedure Y or N, if I hit Y or N it just hangs it will not continue. I tried this both on the IBM and the 486, I also tried changing the address jumper no luck.
Now on the Gen2 Plus, that I have used on the IBM and Fdsik will see the drives but can not do anything with them just says error reading fixed disk. I have this floppy that is an old IBM Dos boot disk I think it's Dos 3 not sure. I also have this newer dos disk bot the IBM will not boot with it I think the floppy can't read it. I can use it with the 486 but can't get any of the controller cards to respond with the 486 so I can't use the newer boot disk.
So if anyone can point me in the right discretion or knows where I can get a proper boot disk that will work with the IBM that has debug let me know, or if there is a way to use any of these cards in a 486 motherboard.
