Reply 7661 of 58849, by easy_john
- Member
May be you know this, but i must say - only old ATX support -5v line, since ATX 2.0 (about 2004) -5v removed from standard.
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 7662 of 58849, by Skyscraper
wrote:May be you know this, but i must say - only old ATX support -5v line, since ATX 2.0 (about 2004) -5v removed from standard.
I think the small "black boxes" are there to fix this issue? 😀
Reply 7663 of 58849, by easy_john
- Member
Ok
Reply 7664 of 58849, by PhilsComputerLab
Reply 7665 of 58849, by hyoenmadan
Would be nice to know what regulator type is under that black box.
Reply 7666 of 58849, by sprcorreia
- Oldbie
Removed from standard but not forbidden (it's optional). I have modern ATX12V PSU with -5V.
Reply 7667 of 58849, by luckybob
- l33t++
wrote:Would be nice to know what regulator type is under that black box.
Probably something like this: https://www.google.com/url?sa=t&source=web&rc … DS56B-NzdLud5uA
Reply 7668 of 58849, by PhilsComputerLab
- l33t++
Larger version: http://i.imgur.com/xHCmoTD.jpg
Reply 7669 of 58849, by Lukeno94
wrote:wrote:May be you know this, but i must say - only old ATX support -5v line, since ATX 2.0 (about 2004) -5v removed from standard.
Budget PSUs using the old designs still come with a -5v rail from time to time, but I'm not aware of any good ones that do.
Reply 7670 of 58849, by sprcorreia
- Oldbie
wrote:wrote:wrote:May be you know this, but i must say - only old ATX support -5v line, since ATX 2.0 (about 2004) -5v removed from standard.
I have a 380W Cooler Master (Hipro).
Reply 7671 of 58849, by Lukeno94
Well, there are some 380W CoolerMasters that are made to ATX 1.3 standards, from what I can see - could yours be one of those?
Reply 7672 of 58849, by Skyscraper
I bought this Geforce 7800GS AGP for 21 Euro + 5 Euro shipping.
The seller also provided this picture, without it I would not have paid this much for it...
Reply 7673 of 58849, by brostenen
- l33t++
Bought this little bad-boy for a small price of 50 Dkr (7,49 US-Dollars)
I have yet to test it out. Besides some small amount of dust, it is in great shape.
EDIT:
Allso. I found a perfectly working and complete HP/Compaq DC7600-SFF desktop computer.
Not really retro, as the system is a 9??-G express chipset machine. Socket775.
The price was 58 Dkr. Anyway. It is going to be used as an machine for recepies and Sims3.
My woman need a computer in her hobby-room (fem'-cave)
Reply 7674 of 58849, by alexanrs
Yesterday I got a new Dallas DS12887a RTC for my P-133. It originally had a VIA82887-based HT12888a. Even though I've read in several places that they are not 100% compatible, the PC works fine with it. And yes, I knew I could try modding the original RTC adding an external battery... and I actually tried that a while ago, but I was a bit careless then and broke one of the battery pins, so I had no choice but to replace it.
I also got this Media Magic Audio16c ISA sound card. Apparently, this is a very close clone of the OPTi 82c929a-based Turtle Beach Monte Carlo... I even used the Monte Carlo's drivers successfully. My only gripe with this card are the crystals: this one has taller crystals than the ones in Monte Carlo, so it interferes somewhat when mounting a WT daughterboard. Might replace them in the future. Also getting this thing going was a bit finicky... I had to assign IRQs, DMAs and port adresses manually in my Compaq's BIOS. This thing needs 3 IRQs (one for SBPro, one for WSS and one for MPU401, and the driver craps out if you try using the same one between two of them)!
This board impressed me: Media Magic apparently copied Turtle Beach very well. The Line Out is cleaner than my YMF719-s cheap card (which wasn't bad in the first place), WSS doesn't give me weird crashes in Warcraft II and SBPro mode doesn't sound as... harsh? Anyway, does anyone know how to switch from SBPro mode to WSS mode from the command line? Unlike the YMF719, this doesn't switch automatically. Also, I had issues using he SBPro part in IRQ5, as this worked in pure DOS but the Windows drivers did not work correctly with it, IRQ7 is trouble-free. Also, does anyone know why this board needs a separate IRQ for the MPU401?
Reply 7675 of 58849, by oerk
wrote:I also got this Media Magic Audio16c ISA sound card. Apparently, this is a very close clone of the OPTi 82c929a-based Turtle Bea […]
Sorry, I don't have answers to your questions, but I recently installed a Shuttle HOT-233 (Shuttle Sound System 48 / OPTi Mad 16 Pro) which is very similar, if not identical. Installation in DOS gave me no problems at all, and the sound quality of the OPL3 is EXCELLENT. Very happy with this card.
Reply 7676 of 58849, by tayyare
- Oldbie
wrote:
I have the almost exact same card, exact latout to last detail except: LS-212 instead of OPL, and Analog Devices AD1846JP instad of big Crystal chip. On the label at the back says "MediaMgic 9501". I tried and look around but never able to find any useful info or drivers. I wonder if yours is also "9501"?
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 7677 of 58849, by frisky dingo
I should have bought 2 🤣
Reply 7678 of 58849, by kixs
- l33t
Now watch the packaging... not really ideal... as I payed 16€ for postage instead of 9€. Because the package was too large for small packages 😵
At least the original box in is a good condition 😈
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 7679 of 58849, by Skyscraper
wrote:Now watch the packaging... not really ideal... as I payed 16€ for postage instead of 9€. Because the package was too large for small packages 😵
We will have to do a AGP vs PCI-E shoot out 😁
The card I bought pictured above should also be a 7800 GT with G71 core eventough its named 7800 GS, sneaky Gainward.
They even made a golden sample version with all pipes and shaders activated... Nvidia was not amused but Gainward sold alot of cards.
