First post, by silikone
- Member
From what I have read, there appear to be three versions of the Sound Canvas 55, where early models lack a General Midi logo, and the late models are branded as MKII.
They supposedly each have some quirks (or features) that can affect games, and these are as far as I can tell:
-MKII doesn't play an instrument at all if a wrong sub instrument is specified
-It also has many extra non-standardized instruments
-Non-GM doesn't understand GM reset
-The same model uses a different instrument where breath noise is usually found
-Some models have a problem with switching between games without resetting first
Is there anything else I have missed?
With these points in mind, which model is usually considered best/most valuable of the three?
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
