First post, by wbc
Hello,
I have a Sound Blaster 32 PnP (CT3600) in my rig for about 2 years, but today, when I turned it on and booted Win98, it started to corrupt some sounds (i.e Windows startup sound, example in attachment), also in some DOS applications (i.e. Impulse Tracker) sound is also distorted (but only from codec\DSP, not from CQM or EMU8000). How it can be solved? I tried to reduce master volume in DOS mixer and it almost helps (some clicks and pops are still hearable). In Windows it also works, but startup sound is still corrupted (file is not, I checked it on another computer). I'm using line-out, not speaker out.
P.S. sorry for zipped wav 😀
--wbcbz7
