First post, by 386_junkie
Guys,
Got this board a while back that had a minor case of a leaking battey, it worked though and I removed the battery as soon as it arrived. The board was relatively undamaged with the exception of a trace between pin 8 (+5v) I believe of the AT power connector and pin 4 which had some signs of corrosion that I had planned to address later.
Of course, with the board working and other projects etc... I forgot! Earlier today I was testing a new motherboard recieved this morning (yay!) but before I mounted the new system I wanted to make sure I was dismantling a working system. Pop! went the old system and came that burnt component smell we have all experienced at some time or other.
Not exactly a great start... but I managed to narrow it down to the open circuit and this yellow resistor type component... does anyone now what it is, it's likely ratings, and where I can find a spare part?
This board is too young to die... and should have a long and healthy life ahead of it!
Thanks in advance.
Reply 1 of 13, by smeezekitty
Tantalum capacitor. They are pretty notorious for short circuiting and smoking/popping.
Reply 2 of 13, by jcarvalho
i should be the same value of the other "C11"
Reply 3 of 13, by alexanrs
If you're going to replace one, you might as well replace both.
Reply 4 of 13, by Sutekh94
That would be a "tantrum" capacitor. Pretty notorious for literally blowing up like the one in the photo. Might as well replace both, as alexanrs suggested.
My YouTube | My DeviantArt
Reply 5 of 13, by smeezekitty
I bet there are a bunch of them. In fact I already see a third.
Reply 6 of 13, by dogchainx
+1
I've had to replace three now on two separate motherboards. Its funny watching them smoking, it looks a matching being lit. 😎
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 7 of 13, by mockingbird
From what I've read from others experiences, tantalum caps either suddenly fail catastrophically like that, or they last forever. I've never heard of anyone replacing a tantalum cap because it was out of spec.
(Decommissioned:)
Reply 8 of 13, by 386_junkie
Guys,
Thanks for all the responses.
There doesn't seem to be any markings that would indicate ratings, and my DMM doesn't do capacitance. The only way to measure them properly would be to isolate one and put it up against a cap-meter?
The one in the photo was connected to +5v, so will look for one similar online with a rating of around 2-3x this?
Does anyone know a good source online where I can just order a bunch of them?
Reply 9 of 13, by 386_junkie
Yea, this is the first time i've required to change these little things, the big caps are no probs and are easier to identify, also with having the markings on their side.
Reply 10 of 13, by smeezekitty
You should be able to remove it and try powering the board again. It will likely work okay without it. Perhaps stability might be slightly negatively impacted.
Reply 11 of 13, by shamino
This tends to happen when tantalums are left unpowered for a very long time (years). I'm not sure if environmental conditions also contribute.
I think if such a board is powered up periodically the tantalums will last basically forever. Realistically, stuff is going to sit around though.
When powering up a board that one considers high risk for a tantalum tantrum, I wonder if using an adjustable power supply would be a good strategy. It might be possible to "warm them up" slowly that way. Hook up to each rail in turn, starting at a very low supply voltage and slowly increasing it. Once they've been broken back in, they should be safe to use normally, I think.
Just a theory - I don't have the equipment to do it, and I guess not many people do. It might also be complicated by the possibility that some circuits won't switch on until some voltage is met, and then the downstream tantalums would still get a rude awakening.
Reply 12 of 13, by 386_junkie
I understand what you're meaning in the general sense, though not sure if it applies here... I attributed it to the open circuit as the track has now completey corroded away. The system may not work well either on a lower voltages that are gradually incremented... lower voltages generally mean higher currents and as a byproduct produce more heat.
Reply 13 of 13, by alexanrs
/\ Lower voltages only mean more current if you keep the power draw constant. This would be the case, for example, in a VRM that is able to compensate for lower voltages. In a normal circuit, if you feed it lower voltages, the impedance will still be the same, therefore the current will be lower as well.
