First post, by maximus
- Member
About a year ago, I took apart my Presario V2000 laptop to clean the heatsink fan assembly. The fan was running fine, but the exhaust vent was completely clogged with dust. While I was at it, I decided to put a few drops of machine oil in the fan's lubrication well, hoping to quiet it down a little.
D'oh! As it turns out, this was a case where I should have left well enough alone. When I put the laptop back together, the fan was noisier than ever. In addition to the old whirring sound, it now made a sort of hissing / rattling noise that seemed to be independent of RPM. I disassembled the machine again, but couldn't find any obvious problems.
After a year of very light use, the rattling noise seems to be gone, but the hissing is as bad as ever. I still can't figure out what the heck I did, or how I might go about undoing it. I suppose I could always replace the the whole cooling unit, but I still would like to know why the oil made things worse. Any thoughts?
