Need Help finding ATI drivers
First post, by Mamba
Hi all,
I' m desperately searching for a working windows98 ATI driver.
I need an old version, catalyst 3.8.
I am not able to find it anywhere, please can someone help me?
Reply 1 of 29, by boxpressed
I don't have it, but I was looking for something similar yesterday. You can find version 3.1 and older on oldapps.com. I finally had to install 6.2 because it was the only 98 version after 3.1 I could find.
Reply 2 of 29, by Mamba
Unfortunately 3.1 doesn't recognize my 9800xt, neither 3.2.
You can find both at k6plus forum (google it).
Need 3.8!
There has to be an archive somewhere...
Reply 3 of 29, by Sammy
Do you know the Date when it was released?
Then i will have a look at my pcplayer, gamestar DVD Collection
Reply 4 of 29, by swaaye
Probably August 2003. 😉
Why go that far back though? The oldest driver I use for a R300 or later card is Catalyst 4.2 and that's only for KOTOR.
Reply 6 of 29, by Mamba
Sammy wrote:
Here i can download the 3.8 version:
http://www.oldapps.com/de/ati.php?old_ati=26
No, they are for xp, it' s a mistake.
I need 3.8 for a socket 7 board. Anyway I will gladly accept 4.2 also, but I really need 3.8
Reply 8 of 29, by Mamba
Yes I had installed them but they are not stable at all.
I need ancient vxd drivers.
Reply 11 of 29, by SPBHM
I see 3.9 on guru3d (win xp section have 98 drivers)
Reply 12 of 29, by Mamba
Can you download them? No.
Thank you, I appreciate, really, but I did it already lot of searching.
I have encoutered hundred times broken links, if you find something please verify.
Reply 13 of 29, by SPBHM
yes, I just tested it
http://www.guru3d.com/files-get/ati-catalyst- … 000%7Cxp,1.html
and many others work.
Reply 14 of 29, by Mamba
SPBHM wrote:
yes, I just tested it […]
The link you gave me is for 3.9 rev5, a sort of "mixed" drivers for particular platform... No go.
Thank you anyway.
Reply 15 of 29, by Evert
On a completely unrelated note, why do you want to run a Radeon 9800XT on a Socket 7 board? Those platforms have horrendous AGP performance and it'll probably be more effort than its worth.
Reply 16 of 29, by SPBHM
Thank you anyway.
driver should be good, the mixed part is control panel and XP, I think anyway.
Asus also have 3.9 (7.95) 98se and the link works
https://www.asus.com/Graphics_Cards/A9800XTTV … pDesk_Download/
see if it works with your card,
Reply 18 of 29, by obobskivich
E-mail AMD support; I've done this a few times for specific old versions of Catalyst. They usually reply within 48h with either the file attached or a direct link to the AMD FTP.
Reply 19 of 29, by PhilsComputerLab
Any chance you can go with XP instead of 98?
I found Guru 3D a great resource.
You can browse back in time, and early drivers see to support Windows 98 as well. Worth checking it out:
http://downloads.guru3d.com/
Click on Videocards - ATI Catalyst XP 32-bit (257 files)
YouTube, Facebook, Website
