Great PC! But can it run Crysis?
Reply 40 of 241, by DosFreak
I can confirm that Crysis works without issue on an Athlon XP 2800+, 2GB ram, 7 32bit, and a decent video card. This is from years ago on my old system that I gave to my brother.
Make your games work offline
Reply 41 of 241, by PhilsComputerLab
ZanQuance wrote:
philscomputerlab wrote:
Trying to get it going my notebook but it crashes 🤣
Well, now I don't feel so bad 😉 it crashes every time on win7 32-bit, I might boot into XP or win7 64-bit and give it a go.
My current rig is a Core2 e8400 @3ghz on a XFX X790i ultra with 8gb ram @1333, and a GTX460 @800-gpu/1000-mem/1600-shader, crashes at stock gpu speeds also, w/latest drivers (<-culprit most likely).
It's weird. The game actually works, but the benchmark crashes. I haven't tried running the full version from Steam. Maybe that will make a difference...
YouTube, Facebook, Website
Reply 42 of 241, by Scali
blank001 wrote:
DX 9.0c is Geforce 6, I'm not sure if FX will run.
Crysis only needs SM2.0 though, as you can see, it lists Radeon 9800 in the specs.
It lists GeForce 6800 as minimum nVidia card, but feature-wise, if the 9800 can run it, then so should the FX, I guess.
I'm quite sure I ran Crysis on my Athlon XP1800+ with Radeon 9600XT. So I don't think it needs SSE2 either.
Reply 43 of 241, by obobskivich
Reply 44 of 241, by PhilsComputerLab
I think we might have to create another configuration for really slow machines. It just takes too long otherwise.
May I present my DX10 Crysis beast with a whopping 1.91 fps:
Reply 45 of 241, by obobskivich
How long did that take to complete? Would I be accurate if I guessed 30 minutes?
Reply 46 of 241, by PhilsComputerLab
Almost an hour 😵
You can just compare the time in the screenshot (system clock) with the start time in the log.
So I've added this third category. 800 x 600, low details, DX9. For machines like a XP or P4 with a GeForce 6 😀
I've tried two notebooks with AMD APU E series processors. DX11 on paper, but all I get are crashes.
Reply 47 of 241, by obobskivich
Reply 48 of 241, by PhilsComputerLab
Interesting with the frames. Maybe there is a pattern with graphics card vendors or drivers?
I'll do another Intel graphics card run, this time on a notebook. Hopefully it doesn't cook 🤣
Reply 50 of 241, by PhilsComputerLab
Yup 😀
Reply 51 of 241, by calvin
I at first tried the 1280x1024 Very High. Yeah, no.
800x600 low? Maybe it'd be playable:
2xP2 450, 512 MB SDR, GeForce DDR, Asus P2B-D, Windows 2000
P3 866, 512 MB RDRAM, Radeon X1650, Dell Dimension XPS B866, Windows 7
M2 @ 250 MHz, 64 MB SDE, SiS5598, Compaq Presario 2286, Windows 98
Reply 52 of 241, by PhilsComputerLab
Nice! So it runs on 512MB? Good to know 😀
Reply 53 of 241, by calvin
Well, it has ludicrous loading times combining low RAM and a slow Fireball making crunching noises, but once it's done swapping everything out, it is actually smooth as it could be.
The Very High demo... yeah, no. Seconds per frame. 0.60 FPS! I noped out of that.
Reply 54 of 241, by PhilsComputerLab
Here the same machines as above, but with the low details settings. The PC is my TV / Server PC. Sits next to my PC, I watch TV shows and movies on it, and it runs a Raid 1 array for some of my files.
Definitely playable!
Don't think I've ever seen such a difference in performance between min. and max.
Reply 55 of 241, by Munx
Pretty common in more modern(ish) PC exclusives. I know STALKER games also have a huge min-max difference.
EDIT: well, here is my little Asus EEE 🤣
My builds!
The Underdog - The budget K6
Reply 56 of 241, by Sutekh94
And I thought this result was bad: (Can somebody say, GPU bottleneck?)
I'll probably do the benchmark again using low settings. Maybe it won't take ~45 minutes to complete 🤣
My YouTube | My DeviantArt
Reply 57 of 241, by PhilsComputerLab
🤣 That's awesome!
Very nice! Yes I think the low benchmark is more suitable 😀
Reply 58 of 241, by Sutekh94
This is more like it!
Reply 59 of 241, by smeezekitty
Your system on low matches up pretty well with my system on high. I guess 800x600 LOW and 1920x1080 HIGH is a significant difference
