2.2V is OK but you need good cooling and dont go higher than 2.2V.
At that voltage the CPU will likely run fine at 6x100 MHz, 5.5x100MHz is guaranteed.
Normally a motherboard that can do 2.2V also can do 2.0V, but the setting isnt always documented. Often you have 4 jumpers, the first jumper adds 0.1V the second 0.2V the third 0.4V and the forth 0.8V, no jumpers at all gets you the minimum voltage of 2.0V. Check if this is how your voltage selection block works.
