First post, by 133MHz
Today I found these two beauties at my usual flea market:
img_20151020_134636820.jpg?w=850
img_20151020_134712936.jpg?w=850
Unlike other Toshiba machines I've come across, I haven't been able to find anything about this one on the web.
Specs:
  • Pentium MMX 233MHz
  • 64MB RAM (soldered)
  • 4GB HDD
  • NeoMagic MagicGraph128XD graphics
  • Yamaha OPL3-SAx sound
  • 800x600 TFT with resistive touch
Available I/O:
  • Ethernet
  • USB
  • IrDA
  • PCMCIA
The power connector is a really small and weird type, holding the probes firmly in place for a quick test was a real pain, but it did the job:
img_20151020_140837448.jpg?w=850
Both units powered up with an IDE #0 ERROR on the screen, one made the usual hard drive spin-up sounds, the other didn't (this one also had a rattling sound). Assuming both drives are likely dead, I took apart the non-spinning one and found out the hard drive was actually loose and rattling inside. Before putting it back on the tablet I imaged the drive successfully on another machine (with the idea of preserving the OEM software and making sure the drive is functional), but back on the tablet it spun up but it still gave the IDE #0 ERROR.
I didn't take a picture, but I believe that the cause of the HDD not being recognized is the CMOS battery leakage reaching the PCMCIA/IDE board, even though the battery is on a long cable and away from the PCBs (typical of Toshiba), there were a few greenish splotches on the board and its interconnects. A quick cursory cleaning with a toothbrush and contact cleaner, and it started right up!
img_20151020_184019967.jpg?w=850
I believe the Chinese WinME install isn't original since there's no Toshiba software or drivers on it (other than the touchscreen mouse driver), bummer. Haven't checked out the other machine's HDD yet.
This is the current situation:
  • At least one of the four batteries seems to be taking a charge. I think I'll leave it charging overnight and try the rest later.
  • The touchscreen calibration is extremely off on the top left corner, so much that the calibration procedure errors out when tapping the top left cross. I have no idea about the cause of this.
  • I can't seem to enter the BIOS setup. There's no BIOS logo or anything, POST is nearly instantaneous. USB keyboard isn't working outside of Windows, and there's no PS/2 port on this thing so I don't have a clue on how to wipe & reinstall for instance.
  • I enabled DMA mode on the hard drive after noticing audio stuttering and effectively locked myself out of the machine. It now bluescreens with a Windows Protection Error, after rebooting the Windows ME boot menu comes up with Safe Mode being selected and auto-started in 30 seconds. USB keyboard doesn't work for changing the selection, and once in safe mode, neither USB keyboard/mouse nor the touchscreen mouse work at all 😒.
Any ideas or suggestions?
http://133FSB.wordpress.com
Reply 1 of 4, by Mr_ppp
I apologise if you have tried this already but if you imaged the drive first could you not restore the image which would also change back the dma setting? At least then you could get back into it 😀
You also weren't joking on the scarce information, I've only found a few chinese websites with similar details as to what you have gleaned, I was hoping there was a similar model number as perhaps it was chinese only? Certainly seems that way from the information I can see
Edit:
The only info I've found that may give a clue is this translated chinese of the history of the Toshiba Libretto line
The history of the libretto
(1) Libretto 20 4月年1996
(2) Libretto 30 11月年1996
(3) Libretto 50 1月年1997
(4) Libretto 60 6月年1997
(5) Libretto 70 October 1997
(6 ) Libretto 100 March年1998
(7) Libretto SS 1000 6月年1998
(8) Libretto SS 1010 10月年1998
(9) Libretto ff 1050 6月年1999
(10) Libretto ff 1100 June 1999
(11) Libretto ff 1100V 10月年1999
(12) Libretto L1 5月年2001
(13) Libretto L2 8月年2001
(14) Libretto L3 10月年2001
(15) Libretto L5 4月年2002
(16) Libretto U1000 2005年April extra edition Libretto 110 (overseas only) DoCoMo mobile pack (Libretto 30) DoCoMo mobile Pack 2 (Libretto 60) DoCoMo Mobile Pack 3 (Libretto M3) Libretto MW1 (DoCoMo prototype) Cuaderia 20 Meiji Seimei smile kun (Libretto 50M) Mitsuiseimei WIN-B Dai-ichi Life navit (Cuaderia 100) Cuaderia 70 (navit prototype?) Addidas Edition (L3) Sofmap color model
Also found this info on another website, could be applicable if it is indeed based on the Libretto line - ignore!!!! I just noticed it doesn't have a keyboard and you stated it doesn't have ps2 port either!!!! 🙁
"This is going to be short and VERY special interest but I wanted to put it out there since I’ve searched all over the internet and back and couldn’t find the answer myself. If you need to get into the bios on your Toshiba Libretto 50CT, reboot it and hold down the ESC key until it comes back with a prompt that says:
Check system. Then press [F1] key.
After that, the rest is pretty obvious. Hopefully this is useful to someone."
Reply 2 of 4, by brassicGamer
My Tecra 740CDT is of the same era (MMX 166Mhz) and this is how I have to enter the BIOS - took me forever to work it out and I use it so infrequently I forget inbetween times. As I have no floppy drive and no CD-ROM boot facility, I have to use another machine to install the OS on the Tecra's hard disk. That's bad enough when you have to remove it from the caddy etc. but your scenario is even worse.
Good find though! If you can get them (or at least 1) working they make a very quirky addition to any collection. It's just a question of how much effort you're willing to put in I suppose. It's likely the hardware is 'off-the-shelf' to a certain point i.e. drivers will be somewhere if you can identify the parts. AIDA might help to identify the hardware and then you can grab the OEM drivers. Shame about the proprietary power socket - could it be replaced? Might require a minor case mod 😒
Reminds me of the Viglen eXaro tablet I have with a Transmeta Crusoe CPU - terrible performance and zero info on the web but still handy somehow.
Reply 4 of 4, by 133MHz
Thing is, in order to get at the hard drive I have to remove:
  • Bezel
  • Digitizer
  • LCD
  • Inverter
  • Battery bay covers
  • Motherboard
And also the FFCs for the inverter assembly and digitizer are starting to wear out (seems it had been forcefully/repeatedly opened in the past) so you can see why I'd rather not pull the drive out to re-image it. 🙄
The OS being Chinese made me think that too, but it doesn't look OEM at all. No OEM branding, no OEM software and registered to Micosoft 🤣
By the way when I turned it on today I got this:
CMOS battery had leaked so it's hardly a surprise, but no amount of USB keyboard mashing or touchscreen tapping got me anywhere, with a quick power cycle I got past it, but it makes me think there should be a way to access the BIOS setup. I find it hard to believe that you lose total control of the computer if you ever fall outside a fully working MS Windows environment. Touch input doesn't work on Safe Mode so I assume it's not falling back to PS/2 mouse emulation or something.
On the plus side, it seems that at least 2 of the 4 batteries actually work somewhat. 😁
Fortunately even if the Windows install seems non-original the all-important touchscreen driver is in there, so worst case scenario I can pull the drivers off the HDD image I made. As for the power connector thing I temporarily removed the power jack and ran wires to the outside.
havli wrote:
As for the power adapter issue - this one might fit eBay
Looks like that's it, but at $32 shipping for a $10 charger I'd rather look for a local solution first. 😀
They are indeed quirky and worth messing around with. 😁
EDIT: Just got this while messing around with the batteries, so the BIOS is indeed touch-aware:
