First post, by rick12373
I have a Pentium II 300 Mhz running Windows 98. It currently has a Matrox Millennium G200 8MB card for the GPU. I use the machine for DOS gaming and games that run only in Windows 98. I like to run games such as Blood, Shadow Warrior, Duke Nuke Em and Redneck Rampage in DOS as well as some other older DOS non FPS games. I tried a few early 3D games in Windows sometimes with good results and other times the GPU is obviously struggling. I was surprised how well Arx Fatalis ran, but it was still just short of playable. The DOS FPS games run well with the Matrox. I already have a selection of old GPUs in my collection and was wondering if I should switch to any of them or stay where I am. They are:
Gateway 16MB NVD01.0 AGP-VGA NV999.0
Creative CT6710 Nvidia Riva TNT 16mb AGP
Diamond Stealth 64 Video 2001 (S3 Trio64V+) PCI
nVidia GeForce2 MX200 32MB AGP
Diamond Stealth 3D 2000 (S3 ViRGE) AGP PCI
What do you think?
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
Reply 1 of 14, by alexanrs
To be fair, that CPU is underpowered even for the Matrox. I'm pretty sure the CPU is the bottleneck there. That being said, you might wanna try the GeForce2 MX200 with older drivers, as I'm not sure which one has drivers with the highest CPU overhead.
Reply 2 of 14, by Cyberdyne
If you want to use Windows 3.1 then Riva TNT, but if you do not, then Geforce MX. It is that simple. S3 cards are very compatible, but not so fast as Nvidia cards. I usually use S3 Trio64 or Cirrus in my 486 builds, S3 Virge and Voodoo in my Pentium builds, and Nvidia and Voodoo cards in my Pentium 2/3 builds. I really do not like ATI cards at all, and Matrox card only shines in good picture quality not speed or compatibility.
Reply 3 of 14, by rick12373
I might try it, I am not sure on what driver would be best for that though.
SB 16 Value CT2770
Reply 4 of 14, by James-F
For me it's S3 Virge/DX or Cirrus Logic 5446, Both work perfectly for DOS 2D games on my Pentium MMX rig.
Can't say much about 3D games or Windows.
Reply 5 of 14, by rick12373
Yeah, I was looking for a little better 3D performance in Windows 98. DOS 3D is good.
SB 16 Value CT2770
Reply 6 of 14, by alexanrs
For 3D in Windows forget the S3 cards you listed. The Trio64 is a 2D only card, and the Virge was so bad at 3D it was nicknamed "graphics decelerator"... its a great card for 2D and for S3D stuff, but Direct3D performance is very bad. For the NVidia cards there stick to Detonators... the 40.xx series of drivers should be good enough to see how it performs in average.
Reply 7 of 14, by rick12373
Thanks I will give the try the Geforce 2 MX200. If anybody wants to swap an ISA Soundblaster 16 for the other cards let me know.
SB 16 Value CT2770
Reply 8 of 14, by rick12373
Well I tried the "Driver 45.23 Detonator FX 9x" from the Vogons driver library and it makes Windows 98 lock up shortly after boot up every time. I am not sure if the card is bad or if I need a different driver.
SB 16 Value CT2770
Reply 9 of 14, by rick12373
Just tried the "Driver 43.45 Detonator XP 9x" drivers and they seem to be OK so far.
SB 16 Value CT2770
Reply 10 of 14, by rick12373
Nope! Still locks up, just took longer. Maybe it is a bad card?
SB 16 Value CT2770
Reply 11 of 14, by alexanrs
You can try the TNT card, as it should be supported by the same Detonators.
Reply 12 of 14, by rick12373
Shouldn't I just stay with the Matrox instead of that? I was trying the other card to see if it would be give a bit of a performance increase to some of the 3D games I run in Windows 98.
SB 16 Value CT2770
Reply 13 of 14, by rick12373
I just noticed that the Geforce 2 was quite hot to the touch, hotter than I think it should be. It could be a bad card.
SB 16 Value CT2770
Reply 14 of 14, by ODwilly
You could try adding a heatsink and fan to the Geforce2, or just get some air blowing over it. I have noticed that alot of Geforce 2 mx200's tend to lack any cooling and tend to run far to hot.
