First post, by feipoa
I have a SCSI HDD with 2 primary partitions,
C: NT4 @ 7797 Megabytes - NTFS - resides from cylinder 0 to 993
D: W95c @ 7805 Megabytes - FAT32 - resides from cylinder 994 to 1988.
The NT4 partition is on the first section of drive real-estate, so from 0 - 7797 MB, and W95c residing from 7798 - 15603 MB. The rest of the HDD is unformatted, unallocated space. I think the total drive size is 36 GB. I have been using the NT4 boot manager to boot between NT4 and Win95c without problem.
This HDD configuration works fine in my PCI-based 486 system w/Am5x86. The PCI-based 486 system is using an Adaptec 2940U2W SCSI controller (68-pin).
When I connect the HDD to my VLB-based 486 system w/Am5x86 and an Adpatec 2842A VLB SCSI controller (via a 68-pin to 50-pin converter), I can only boot into NT4. When I use the NT4 boot manager to select "Windows 95", I get, "Disk I/O error - Replace the disk, and then press any key". I have the VLB SCSI controller set to use Extended BIOS Translation for DOS drivers > 1GB. Extended BIOS Translation allows DOS access up to 8 Gigabytes (1024 cyclinders, 255 heads, 63 sectors).
The PCI-based 2940U2W SCSI controller also uses Extended BIOS Translation, but why can I boot fine with 2940U2W and not the VLB-based 2842A? How do I overcome this? Must the entirety of the NT4 and W95 partitions fall within 8 GB? If so, then why not on the 2940U2W card? I thought that as long as the boot sector of the W95 drive fell within the first 8 GB of HDD real-estate that Win95c should boot fine. Or is the extended BIOS translation on the 2842A card slightly different than on the 2940U2W card?
When I am in NT4 on the VLB-based system, I can access the Win95c partition without problem.
When I use the Partition Magic 8.0 boot disks and run chkdsk, the NT4 partition comes back error-free, while the W95c partition comes back with Error 57 - "cylinder number is too large for BIOS". I assume it is refering to the SCSI card's BIOS.
[Side Note: to get the NT4 and Win95c FAT32 to get along, 1) install FAT32 for NT, and 2) use a program called dd.exe to create an image of the Win95c partition's boot sector and place the 512 byte boot sector file onto the NT4 partition, then add c:\bootsect.w95="Windows 95" to your boot.ini file.]
How do I get the Adaptec 2842A to boot my second Win95c partition? Any ideas?
Reply 1 of 53, by matze79
Try PLOP Bootloader or Sbootmanager
Reply 2 of 53, by feipoa
So you have run into this problem before and PLOP and Sbootmanager were able to fix it?
Reply 3 of 53, by Malvineous
Don't forget that it's not enough for the boot sector to be within whatever barrier you are up against. The BIOS needs to load the boot sector, but the first thing the boot sector does is ask the BIOS to load the next lot of data, e.g. IO.SYS, NTLDR, etc. If that's beyond the barrier then the BIOS won't be able to load that either. This is why the recommended advice is to ensure the entire boot partition is below any barrier, so an inadvertent defrag won't render your system unbootable by accidentally moving the bootloader files beyond the barrier point.
Is it a problem to use four partitions instead, with C: and D: being small boot partitions, and E: and F: being the respective data partitions?
I am guessing that the difference between the controllers is down to the maximum cylinder values they use during translation. Perhaps one has a max of 1023, and the other is 1022 or similar. The actual translation algorithm appears to be the same, otherwise the filesystem would appear corrupted on one of the controllers (at least until Windows loads, when it should use LBA access and the SCSI BIOS doesn't have to perform CHS translation anymore - this would be why you can see the whole disk fine once NT has loaded.)
Have you tried putting the VLB SCSI controller into your PCI system? That would at least confirm whether it's the controller's BIOS to blame. The error about the cylinder number being too large for the BIOS typically refers to the system BIOS, so you may find that either controller works fine in the PCI system, and it's a limitation in the VLB system's BIOS.
Reply 4 of 53, by elianda
On booting the loader uses bios functions and thus the bios limits apply. So all the required files have to be on the disk below this limit. This is overcome as soon as the mass storage driver starts (e.g. for NT4 as soon as the kernal boots).
Following this behavior you can even install NT4 on a 120 GB partition as long as the relevant boot files stay within the first e.g. 8 GB.
Youtube Channel
Reply 5 of 53, by hyoenmadan
Why he should want 2 small boot partitions? That's only necessary if he wanted to dual boot Windows with any *nix flavor, but this isn't the case. With only 1 small boot partition you can dual boot NT and W9x/DOS, as soon as the small boot partition keeps formatted as FAT16. If you have Win95 OSR2 or WinNT SP6a, you can even send your OS partitions beyond the 32GB barrier, as soon as the boot files keep inside the BIOS barrier (Win95 IO.sys or WinNT NTLDR/NTDETECT.COM/BOOT.INI).
Btw, once the SCSI disk is connected to an specific HBA and formatted/partitioned with it,you can't move safely that disk to other HBA, unless you format it in the destination HBA again. In older days every SCSI manufacturer had their different way to do stuff, like HDD geometry translation and such, and unlike IDE, such ways weren't standarized at all. Many problems with booting SCSI stuff in these older days came from people misunderstanding SCSI ways, and thinking that preparation procedure steps were the same as with IDE disks.
Reply 6 of 53, by feipoa
Thank you for your responses everyone.
So even if I had created two 4 GB partitions, one for NT4 and one for W95c, you're saying that the VLB might not boot W95 still, e.g. because the different host controllers format/treat the hard drive differently? However, considering that NT4 loaded fine on the VLB controller, is it fairly safe to assume that the two host controllers are compatible in this respect?
From the responses, it sounds like some of my Win95c boot files are passed the 8 GB barrier and this is causing the problems with booting. So if I use partition magic to shrink my NT4 partition down to 7000 MB, how do I stick just the W95c boot-required system files onto the next 1000 MB? I could create a 1000 MB boot partition, whereby partitioin 3 would be the Win95c partition with the rest of the files. While it is straight forward enough to install Win95c to that 1000 MB partition and all the program files onto the 3rd partition, I would ideally like to keep just the boot-required Win95c files on that 2nd partition.
Reply 7 of 53, by matze79
i didnt try it, but it is worth, just write a floppy disk.
plop even allows usb boot on 486.
Reply 8 of 53, by feipoa
Responding to some of the comments posed above:
- PLOP did not allow the Win95c partition to boot.
- My Asus PVI-486SP3 (1 VLB + 3 PCI) does not recognise the HDD when using the Adaptec AHA-2842A VLB SCSI card. My PC Chips M919 (1 VLB + 3 PCI) also does not recognise the HDD when using the VLB SCSI card. So I can not determine if the issue is due to a motherboard BIOS limitation or strictly due to the VLB SCSI card's BIOS.
- It looks like I may need to setup this HDD another way. Does anyone know which files Win95c needs just to startup? I'd like to create a small Win95c boot partition, perhaps 100 MB if possible.
Reply 9 of 53, by Malvineous
Since Win95 seems to be the problem, can you try putting that first (C:), and NT second (D:)? Maybe NT's boot sequence is smarter than Win95 and it's not as flummoxed by large disks.
Reply 10 of 53, by feipoa
I sorta recall WinNT4 needing to be installed on the first stretch of HDD real-estate because I am using FAT32 for Win95c. Maybe I am mistaken?
Reply 11 of 53, by Malvineous
Not sure - I've never used NT. If it doesn't recognise FAT32 you'd think it would treat it as a non-DOS partition and leave it alone?
Reply 12 of 53, by feipoa
Something in the back of my mind is telling me that NT4 needs to put files on the first partition to boot properly and having FAT32 messes this up. Even though FAT32 for NT4 works in NT4, the driver only gets initialised later in the boot process.
Reply 13 of 53, by alexanrs
Replace the bootloader with the one from Windows 2000 (NTLDR, etc.) in the root partition.
Reply 14 of 53, by Malvineous
Well...you could get crafty, and set up your partition table such that the first partition starts at 7000MB, and the second partition starts at 1MB. Then NT would get the first partition, and Win95 would be within the 8GB boundary... Nobody ever said the order in the partition table had to match the order on the disk 😉
You'll of course need a non-Microsoft program to set up the partitions this way though.
Reply 15 of 53, by feipoa
I think I tried that once and it didn't work (or my memory is false). Do you know for certain this configuration will allow NT4 to boot when the first partition if FAT32?
Reply 16 of 53, by feipoa
This is an interesting idea. How do I tell the partitions who is #1 and #2? But maybe NT4's being fussy about having the boot files on the first partition is a cylinder # issue?
Reply 17 of 53, by alexanrs
I remember doing that with NT 3.51, and it booted NT just fine. I don't recall experimenting with making the boot partition FAT32, though, but since Windows 2000 boots from FAT32 partitions just fine, it should work.
Reply 18 of 53, by feipoa
Exactly which boot loader files from W2K do I need to copy into NT4? If I recall correctly, I think I only copied NTLDR previously. Are there others I need to copy over?
Reply 19 of 53, by alexanrs
I believe you need at least NTLDR and NTDETECT.COM. You might like reading this page.
