feipoa wrote:Responding to some of the comments posed above: […]
- PLOP did not allow the Win95c partition to boot.
- My Asus PVI-486SP3 (1 VLB + 3 PCI) does not recognise the HDD when using the Adaptec AHA-2842A VLB SCSI card. My PC Chips M919 (1 VLB + 3 PCI) also does not recognise the HDD when using the VLB SCSI card. So I can not determine if the issue is due to a motherboard BIOS limitation or strictly due to the VLB SCSI card's BIOS.
- It looks like I may need to setup this HDD another way. Does anyone know which files Win95c needs just to startup? I'd like to create a small Win95c boot partition, perhaps 100 MB if possible.
- PLOP will not help you to fix the 4GB hdd barrier for SCSI disks, because in these cases INT13 data to patch ins't in the system bios data area, but in the SCSI card BIOS data area. PLOP can only patch system bios data area, and its INT13 extension driver will only work with IDE disks. The same applies for any overlay disk driver.
- Win95 setup allows to installl windows in a different partition from C. If you let setup take care about it, it will create necessary files in C: and the rest, including program files and windows folder will be installed in the OS partition.
- NT setup can do the same as Win95.
- You want to install Win95 in the first OS partition, intro the 4GB barrier. That's because NT allows a little trick to bypass the barrier that Win95 doesn't allow.
- Trick is copying NT4 SCSI port driver to the small boot partition where NTLDR resides, with NTBOOTDD.SYS name, and changing nomeclature in boot.ini as follows: from multi( 0 )disk( X )rdisk( Y )partition( Z ), to scsi( 0 )disk( X )rdisk( Y )partition( Z ). This will allow NTLDR to use your card 32bit full driver, and will bypass any card bios barrier. Use always the most updated version of your port driver
More info about this here.
In the end, your layout will end like this: [Primary, Boot Partition, 100 to 300 MB, depending in your needs] [Extended Partition, Rest of Disk (Win95 Logical Volume, Intro the 4GB Barrier)| 4GB Barrier | (NT4 Logical Volume)]
Boot partition needs to be created with HBA tools from DOS in the destination SCSI HBA. The rest can be created from inside any OS with tools like DIskpart (use XP/2003 server version), or partition magic inside windows, to access the full disk using the full 32bit port driver.
