Hi 😀
Has the issue been resolved?
I googled your motherboard and apparently it's very similar to 2 motherboard models I have somewhat extensive experience with (the A7V and the A7V133).
As I was gifted around 8 or 10 or so of these boards (I really should count them 🤣) from where I used to work and we worked with tons of these boards for a year or so (We got >20 of these from a school or something) I have done quite extensive research years ago and there used to even be a forum specifically about these early Socket A ASUS boards, which sadly is now gone. It did contain a LOT of very detailed information and experience stories of which I kept very little, but 2 things I did remember:
1) There was a way to install several DIMMs and have the least chances of the system running unstable
2) The Palomino was supported by rev "1.05." which should be a sub-revision or something which came right after the "1.05" (1 dot instead of 2)
I do remember that these ASUS boards had a lot of quirks and were very picky, but with these tricks (and some others which I don't remember anymore) these boards could actually be gotten to run in a way that (don't choke 🤣!) can be described as stable and solid.
The memory thing was something like this:
The 3 memory slots are numbered and iirc on these boards they were numbered in reverse (so the first one was farthest away from the CPU instead of closest which is more usual), the first slot being the right one instead of the left one.
What I read and what I did was carefully pick 3 DIMMs which were as similar as possible. The first DIMM I would pick a DIMM with 16 chips and (this is an example) 512MB and put this DIMM in the first slot. The other 2 DIMMs would be 256 MB each and have no more than 8 chips (so basically exactly like the first DIMM, but "cut in half").
Most important was memory chip density had to be exactly the same with all memory modules used on that board or it would be unstable. Whenever possible, I'd even use DIMMs of the same manufacturer, whatever, I'd pick DIMMs which were as close to be similar to each other as I possibly could.
The largest DIMM is PC-133 Kingston? I'd try to use 3 Kingstom DIMMs, the first one 16 chips and the other 2 with only 8 chips and half the amount of memory so all 3 DIMMs use chips of the same memory density.
I've build at least 3 rigs around variants of your board and at least one had 1x512MB + 2x 256MB, the other had 1x256MB and 2x128MB, both seemed to not be very problematic. I even ran one 1.05 (no dot) with a Palomino and it ran very well, even though the board officially didn't even support Palomino.
Sorry for the long write, but I promise it will soon be over 😁
I should still actually have these 3 rigs I build, one is even here in the living room and the other 2 (which I basically only used to run SuperPi) are probably either still in the attic or outside their case, but still with the parts together in a box (and with the memory modules still installed), I could take a look what other things I did with these boards.
Hope this helps 😀
