First post, by Great Hierophant
- l33t
I recently acquired one of these from a friend of mine and I have been putting it through the paces. Here is how it stacks up:
The Good :
Pentium 120MHz MMX with up to 32MB of RAM. Cache control in the BIOS allows for turning off. Can be overclocked to 166MHz.
Video is a Chips and Technologu F65550 with 1MB EDO DRAM, it can do 640x480@24-bit, 800x600@16-bit, 1024x768@8-bit and 1280x1024@4-bit. Video is at least decently speedy and should be reasonably compatible. The internal display has a 640x480 native resolution. 320x200, 640x200 and 640x350 DOS games all look perfect with letterboxing. Text mode stretching can be turned off in the BIOS.
Enhanced port replicator gives a serial, parallel, VGA, PS/2 mouse and keyboard and second PCMCIA, so you can use it as a PC without needing to type on it or look at the screen. The port extender gives only serial, parallel and VGA. With two ports, you can use a floppy, CD-ROM and/or a Network Adapter.
Sound is the Yamaha OPL3-SA3, with native support for Windows Sound System and good Sound Blaster Pro emulation. True Yamaha OPL FM Synthesis.
The keyboard has decent sized keys for the most part and full cursor keys.
Hard drive up to 2GB support.
The Bad:
No indication of external CPU cache.
Accessories like manuals, floppy drive, port extender and replicator, battery charger, replacement batteries, 16MB memory expansion, etc., may be hard to find.
Needs external CD drive to be really useful, which will likely connect via PCMCIA or parallel port.
Screen is only 6.1" on the diagonal, and is a bit dim and 16-bit panel. Mine has 4 stuck subpixels. The text mode fonts look quite different from IBM's.
Keyboard has some tiny keys, keyboard is mushy and the nub is no fun to use.
Hard drives over 1.6GB will not be supported if BIOS past 6.2 is used.
Internal speaker for sound card will distort at medium volumes. Needs a 2.5-3.5 adapter.
Game port must be on a PCMCIA card, very hard to find.
