First post, by joc
Does anybody know something about this card? It's AGP, A1264-66501.
553.55 KiB
I have no picture on my monitor with VGA port but card turns monitor on. I will try with DVI later...have no DVI monitor nearby.
...so I use S3 Trio as primary VGA, mobo FS Celsius slot2 with dual pentium2 xeon.
Can this card support any Windows or Linux?
Data from CNET: OS Required : HP-UX 10.20, HP-UX 11.0, HP-UX 11i That means no?
http://www.cnet.com/products/hp-visualize-fx5 … b-series/specs/
Tried to load Matrox drivers, got this...
28.15 KiB
Unknown devices utility:
121.74 KiB
Reply 2 of 6, by joc
Pics of FX10:
http://old.vgamuseum.info/history-tree/item/4 … -tvga8900b.html
My pics can't be that nice.
FX5 have 1 chip less and cost 900$ less 😀
Edit:
Second pic from right: Driver version: 1.18 F1 (Windows2000) 🤣
Gotta find!
Reply 3 of 6, by vlask
Card does have driver support for Windows XP, W2k and linux. Its basicaly cut (one less chip) version of FX10, they share also drivers - you can see info at mine pages - http://vgamuseum.info/index.php/cards/item/72 … -nt-a1264-66502
There were 2 versions - AGP should be PC compactible. They did also UNIX version for PARISC cpus based connected with PCI/4X - these probably wont work on usual mb. Why isnt your card working i dont know...
    fx_w2k_118b.zip
    1.93 MiB
    120 downloads
    HP Visualise FX5/10 W2k/XP driver
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 4 of 6, by joc
To the basement!
edit:
Card is dead but not as dodo.
Driver installs "firs portion" of card. Lower part(vga compatible) stays uninstalled and unrecognized.
Now I have second monitor in display properties. Computer freezes when I try to enable it.
DxDiag "see" just my primary S3.
It was nice to play with this card for few hours.
Reply 5 of 6, by joc
Found (by now) 2 missing smd. I think blue one is a resistor, other is some cap.
On the other side of PCB is G200.
22.89 KiB
Reply 6 of 6, by joc
Tried few resistors 8k-50ohms, no change.
DVI monitor not turn on when computer starts, VGA does.
Put it in Abit KT-7, same results.
Computer starts, VGA monitor turns on, no picture, no beep.
On my really old oscilloscope I can see H and V sync signal but no RGB.
2 more options left
Reflow oven and card bios
Whitch bios tool to use with this card?
I have FX10 bios, cant find FX5.
