First post, by keenmaster486
- l33t
I have a K7T Turbo2 Socket 462 motherboard, which I pulled from a recycle center find (somebody's homebuilt machine).
I powered up the machine before I removed the motherboard and it worked perfectly. All I wanted was the case, so I removed
the insides (except for the PSU). Now it's been five days and the MB has done absolutely nothing except for sit on the table.
I figured I'd sell it, so I went to power it up and take some screenshots. Hooked up the PSU, original video card that came with
it, original Athlon CPU that came with it, monitor, keyboard, mouse. I also loaded it up with as much RAM as I could stuff in it,
just to make sure everything worked for prospective buyers.
I hit the power switch and I got some warning beeps - oops, I forgot to put the heatsink and fan back on. I did that, but now
when I try to power it up the fans run, but nothing happens. No video on the screen, no beeps, no nothing. I've tried a zillion
different video cards, three different PSU's (known to be working). I tried every different stick of RAM I have in the house, in
every slot; nothing works. I've tried running it with no RAM and no video card, to try to get some error/warning beeps, but nothing.
I've tried it with no CPU loaded; nothing.
So what happened? Did I somehow fry the thing by not having the heatsink and fan in when I first powered it up? What's going on?
Should I be trying it with the original PSU that came with it? Does it need to be in the case and grounded to work at all? (I've never
seen that situation before, but you never know...)
I also have another (much older) motherboard that has this same problem. It had the dreaded capacitor plague when I got it,
so I replaced every capacitor on the thing, but still nothing except that the fans run.
Could somebody please help me diagnose this problem?
World's foremost 486 enjoyer.
