First post, by weldum
Hello.
I have a PCChips M919 V3.4 (the one with fake "Write Back" cache chips) that works very well but I want to know what is the max cacheable ram size.
Currently it has 68MB (2x32MB EDO 60ns + 4x1MB FPM 60ns)
Also, what's the best post 94 operating system for an AMD 5x86 133MHz?
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 1 of 7, by Skyscraper
With a 256KB cache stick the cacheable range should be 64MB "write through" and 32MB "write back"
If you choose to run Windows 95 I would remove the 4x1MB and make sure the board runs the cache as write through . If you only use DOS and Windows 3.1/3.11 which is the period correct OS for 1994 I would probably only keep 1x32MB memory and run the cache as "write back".
Reply 2 of 7, by weldum
The problem is that I don't have any of these non-COAST sticks, and there are near zero possibilities to find one.
I have to make it work without cache sticks.
Reply 3 of 7, by Skyscraper
Then the cacheable range is 0MB, use as much memory as you like.
I would still remove the 4x1MB as they probably cant handle as tight timings as your 32MB sticks.
Reply 4 of 7, by melbar
It's a really curious board your have! Very fast chipset, but no cache or same fake's soldered onboard...
But with fast chipset + all three slot types onboard... really bad that a COAST won't work with it. Yes, i think it's hard to find the right cache.
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 5 of 7, by weldum
Also, I've heard some people say the chipset auto configuration option in BIOS should be disabled to avoid performance problems.
How do I configure the memory timings? Have to do trial and error? Thanks
Reply 6 of 7, by Skyscraper
When it comes to memory timings lower numbers are usually better than higher numbers.
It is a bit of trial and error though.
Reply 7 of 7, by weldum
cachechk tells me I have 56Mb cached via L1 cache (16kb) so I put 32mb edo and windows 95 and it works much better now. Thanks to everyone.
