First post, by Formulator
I have recently acquired a CT1300B in a box of sound cards. I am unable to produce sound from the device, after trying in various XT systems. Port is 220, INT 80H. CMSDRV.COM locks up as well as TESTCARD.EXE. It would be nice to produce sound from this piece of vintage history. Any perspective will help. Thanks.
Reply 1 of 15, by Jepael
Do you have anything else that could exist at port 220h?
If the CMS chips are socketed, they could have bad contacts between socket and the chip, so try to push it a little bit back in the socket.
On some Sound Blasters, if the CMS chips were not installed, reportedly, accessing them caused the machine to hang. And I suspect that's because the sound card circuitry tried to add wait states until the CMS chip acknowledged the bus cycle, and it was not present to acknowledge anything.
Reply 2 of 15, by Skyscraper
The CT1300B is a Game Blaster so it has only CMS support and no socketed chips.
The CT1350B is a Sound Blaster 2.0 with sockets for CMS chips but no CMS chips installed.
Reply 3 of 15, by Formulator
Here is a better picture of the card. I have tried different addresses as well, so I feel like I am missing something basic here. I'll post some screenshots soon.
The attachment IMG_0021.JPG is no longer available
Reply 4 of 15, by Skyscraper
That card should work one would think, it looks pristine. Have you tried it in a newer system like a 386?
Not that it shouldnt work in a XT, Im just covering all bases as I dont own anything slower than a 286 my self.
Reply 5 of 15, by MMaximus
Is this one of the cards requiring -5v from the PSU?
Hard Disk Sounds
Reply 6 of 15, by PeterLI
Looks fine. Do you have a picture of the back?
Try it in an 8BIT slot in a < 386 PC.
Reply 7 of 15, by Jepael
I don't think the card needs -5V for anything. Or -12V.
The digital logic should just use +5V. The TEA2025B is a single supply speaker amplifier, and it works fine with +12V.
The CMS chip output needs filtered +5V, but that's made with el cheapo 5.1V zener shunt regulator from +12V.
Man, that is a good picture of the card, I see the components and connections. If it's possible, could you provide some markings on capacitors as well?
Reply 8 of 15, by keropi
Had one in the past, didn't need anything special to work - much like an AdLib card. You plug it in and it just works...
Reply 9 of 15, by Formulator
OK, a view of the back of the card. I never noticed it before but there is some gold missing on a few teeth:
The attachment IMG_0025.JPG is no longer available
Reply 10 of 15, by keropi
Hmmm... Try and clean the isa connector with some IPA and a pencil eraser , maybe the problem is bad contact with the isa slot
Reply 11 of 15, by carlostex
Yes try cleaning the connector, always worth a shot. The card seems absolutely fine. It could be that just one of the LS series IC's which do the interfacing to the ISA bus is dead.
Reply 12 of 15, by Great Hierophant
Hey, I'm sorry that I never responded to your PM, but I would suggest trying some Game Blaster compatible games and seeing if they produce sound. Most GB-compatible games bypass the detection that TESTCARD and CMSDRV use with the big CT-1302 chip. Any Sierra game will do. It is a long shot, but it's worth trying.
Also, this may be an obvious suggestion, but you said you were using it in an XT. If you have an 8-slot IBM PC XT or clone, do not use it in slot 8.
Reply 13 of 15, by shock__
Apart from that: have you tried adjusting the volume potentiometer?
It might be crusty or turned down all the way.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 14 of 15, by Malik
I was thinking along this line too.
Edit: But it shouldn't hang the system when the driver was loaded.
Reply 15 of 15, by matze79
did you try another computer ?
i would try to replace the 74series IC's.. its worth to try it
