PnPray trouble.
First post, by ExTneicsol
On my dos rig i tested a audio pnp audio card, the mobo (p5a) doesnt detect it at the power up but does after a reset. 😼 it is a bit weird. Does it ever hapened to anybody else?
Reply 1 of 6, by Half-Saint
have you tried other pnp cards with that mobo?
Reply 2 of 6, by HighTreason
As Half-Saint suggests, try another card if you can. If that card is detected immediately it implies there is no problem with the motherboard. This might indicate a capacitor is going bad on the card and it taking a while to hold charge, causing the card to need a "warm up" period before it will work properly, this would be fairly easy to correct.
Reply 3 of 6, by ExTneicsol
I've an old pentium 2 board i will test the sound card on it. The fact is that the card is brand the new. And i have some trouble in windows detecting (windows 95) the card in question and my awe32 that worked before ... strange.
Reply 4 of 6, by ExTneicsol
I've tested it on a AT pentium board ... detect it righ away and every time! I was a bit disapointed since the audio card is the Compaq Ultra-Sound 32 Pro. But if it work every time on another mobo ... could it be the -5v rail?
Reply 5 of 6, by brostenen
Testing with another PSU won't hurt. I think that you can see the voltage ratings somewhere in the BIOS on the P5A.
Reply 6 of 6, by ExTneicsol
I have the bad revision of the p5a ... the one that doesnt like the amd k6-2/3 +
I will check the voltage in the BIOS and swap the psu. If it is detected everytime on another modo ... it shouldnt be the card.
