First post, by kixs
Hello,
what is the easiest and bulletproof test of Gravis Ultrasound ACE? Would like to see if it's in a working condition or not.
At the moment I have a Pentium 133 on my desk. Should I install a Soundblaster along with ACE?
Thanks
Reply 1 of 16, by gdjacobs
The ACE was intended to be paired with another sound card, so it sounds like a good idea to me.
Reply 2 of 16, by Great Hierophant
How does installing another sound card test the ACE functionality? First you must install the DOS drivers, then I would suggest trying a game. I wrote about driver issues here : http://nerdlypleasures.blogspot.com/2012/07/g … -dos-games.html
Epic Pinball Shareware 2.1 can be downloaded from here, it is a good test for Ultrasound functionality : http://www.classicdosgames.com/game/Epic_Pinball.html
Reply 3 of 16, by kixs
Did as Great Hierophant suggested...
1. installed only ACE card
2. installed the drivers for DOS (I was missing this step - for Soundblasters I have the necessary files always on HDD)
3. run the Epic Pinball demo and YES, there is sound 😁
4. installed the drivers for Windows 95.
To do:
5. I have to check if any SOJ memory chips I have are good for ACE.
Is there an utility/command to see the memory size installed on the card (to verify if additional memory is OK)?
What actually worried me was that the usual System info tools didn't find ACE. Now AIDA shows it's present and also shows the installed memory - 512KB at the moment 😀
Thanks 😁
Reply 4 of 16, by kixs
Found the right memory chip and has 1MB of memory 😀
Now I have to decide what is the best combo for old games 😕 🤣
1. SB + ACE
2. SB + Roland compatible daughterboard (like TerraTec SOWT-24 V2)
3. SB + SCC-1
4. All-in-one card (like TerraTec EWS64 XL)
What is the recommended setup?
Reply 5 of 16, by brostenen
kixs wrote:
Found the right memory chip and has 1MB of memory :happy: […]
1. SB + ACE
3. SB + SCC-1
SB + ACE + some sort of MIDI daughterboard. (If I am only to pick from you'r list)
Reply 6 of 16, by kixs
Never thought about triple combo 🤣
It's a possibility of course...
This might be a tought one for me as I've never put much about music and I'm kinda lost in this field... but it's bound to change 😉
Reply 7 of 16, by bjt
Second Reality or Crystal Dream 2 are also great GUS tests. Don't require any drivers apart from normal ultrainit.
I vote for SB/GUS/SCC-1, if you have the slots. That way you don't worry about SB hanging note or other MIDI issues.
I run AWE64/GUS Classic/Voyetra Midi card in my machine, they play nicely together.
Reply 8 of 16, by brostenen
Just make shure to route the output from the SB into the ACE and from the ACE to the speakers/amplifier/stereo.
Another thing to consider, is if the ACE is the first or the later releases.
The first ones, had stereo reversed. This is no big deal, as you reverse each cable, ending up with correct stereo.
EDIT:
I actually wonder what happened to the ACE that I sold just last year.
The buyer has not responded in any way, not even telling if the card arrived.
Must remain a mysterie then. 🤣
Reply 9 of 16, by gdjacobs
Great idea! I'd suggest a newer Vibra 16S (lower noise) card with a genuine OPL3, but you could use a Pro if you prefer. This gives you SB(16), GUS wavetable, and normal mode MPU-401. On the SCC-1, you can use either the onboard SC-55 functionality or literally any module that can use a MIDI port. Play MIDI via another computer system if you like as in Phil's video.
I can't think of any important DOS sound API this doesn't cover, and the hardware is pretty much orthogonal in function (not much overlap). It would give you a fantastic setup.
Reply 10 of 16, by kixs
SCC-1 isn't in my hands yet. The ACE is version 1.0 - but that's just fine. I'm just happy that it's working 😁
EDIT:
Just noticed this is my 1000 post 🤣
Reply 11 of 16, by gdjacobs
I'm personally pessimistic over sourcing an SCC-1 or another normal mode MPU-401 for a sane price, so I'm going to build a HardMPU. You could also poke Keropi about when he's going to gin up another batch of Music Quest clones.
Normal mode MPU-401 is key.
Reply 12 of 16, by kixs
I'd like to test drive 1MB memory on my ACE now. Any suggestions what to run?
Reply 14 of 16, by dr.zeissler
ACE and AWE64G do not work together 🙁
The Joystick of the AWE64Gold seems to be at the same address of the gus-ace.
But the GUS ace is working fine with 260,3,3,3,3.
While Taking out the GUS, everything is OK.
Changing the AWE Joy to 208, then everything is OK.
But after some reboots the joystick is at 200 again.
shit pnp fuck.
Reply 15 of 16, by firage
The ACE has its non-existant joystick port enabled by default and needs to be disabled with ULTRINIT v2.26a using the -dj parameter. Did you try that yet?
My big-red-switch 486
Reply 16 of 16, by dr.zeissler
It is disabled with -dj.
