Reply 12300 of 53165, by stamasd
I've used Aliexpress many times in the past 2 years. Usually it works without any hassle, pretty much similar to ebay. However be prepared to wait for your item for a long time, usually 3-4 weeks. The few times that I didn't receive the item I got the money back without any trouble. They use a payment system called Alipay, and the seller doesn't get the money until you confirm that you received the item (until then the money is held in escrow). So you don't have to go after the seller to get the money back, it's returned to you from the escrow.
The latest items I ordered from Aliexpress were some YM3812 and Y3014 chips to build an OPL2 card. I placed the order on 4/11 and received them on 5/15.
If it's this lot http://www.aliexpress.com/item/V53C104HP45-DI … 62-dea629a24624 it says "contact the seller before ordering" and I suggest that you do; some sellers put that notice on lots that they're not sure they will have the items in stock all the time.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
