First post, by 8bitbubsy
- Member
I have a mysterious problem with my UC4913 ver2.0 486 motherboard when using a DX4 (it's fine with DX2)... It's a Socket 3, but it doesn't have a voltage regulator. I tried to short the sense pins and measure the vcc, and it's indeed 5v. The CPU is correctly identified as a DX4 in the POST screen.
Anyways, when I install a DX4 with either a voltage adapter kit or a DX4 Overdrive (built-in volt reg), I keep getting "Parity Error" crash after playing games and stuff, especially when sound is playing. I've tried to remove everything except for the video card and I/O card, and I keep getting the same issue. I've tried to reset BIOS to default (to prevent potential overclock issues) and it doesn't help. I've also ran a full memtest86+ (while on the DX4) with no errors, and I'm fairly certain that the external cache is in good shape (15ns 256kB - are there any programs out there to test it?). Also tried to use another set of RAM sticks, no go. Oh, there are no IRQ conflicts either!
The very strange thing is that if I plug in a standard DX4 without a voltage regulator (nasty), the system is way more stable. I use a heatsink and a fan, because it runs insanely hot on 5v. I have another DX4 that crashes quickly on 5v, but this one works for a long time.
Any ideas..? I've tried a totally different I/O card, another sound card, and made sure that all the jumpers are correct on the mobo. The PSU has been recapped with low-ESR nichicon PW(M) series, so the PSU is most likely not the problem. As said, the system is dead stable on a 5v DX2-66.
I have a feeling that a component on the motherboard is out of spec (resistor, diode, capacitor, transistor etc), but I have no idea... One would think that the only difference is the 3x clock and the 3.3v logic inside the CPU..? 😒
EDIT: I'll actually desolder the mobo caps one by one and ESR+capacitance test them and come back here with the results.
386:
- CPU: 386DX-40 + 40MHz FPU + 128kB L1 cache
- RAM: 8MB (0 waitstates @ 40MHz)
- VGA: Diamond SpeedSTAR VGA (ET4000AX 1MB ISA)
- Audio: Sound Blaster Pro 2.0 + GUS 1MB
- ISA PS/2 mouse card
- MR BIOS
