Xi 8088 by Segey Kiselev
Reply 20 of 613, by BloodyCactus
nice! my one part mouser didnt have that jameco did came today. the tiny trim pot 🤣! so small. just waiting on my v20 from china.
Reply 22 of 613, by BloodyCactus
sockets and decoupling caps, battery holder, ps2 connections...
Reply 23 of 613, by keenerb
Apparantly I ordered the wrong RTC:
Do you think the DS12C887+ will be compatible with DS12887A+ that the BOM suggests?
www.mouser.com/ProductDetail/Maxim-Inte ... J8VExDE%3d
vs.
http://www.mouser.com/ProductDetail/Maxim-Int … P35CksHxtng8%3D
The only difference I can see seems to be that the suggested part has "binary" date/time, but one of the Jameco suggested pieces does as well. Does the "C" stand for CMOS as it did for some of the other parts?
Also, I JUST realized I have no way to program the BIOS on this thing...
Reply 24 of 613, by brassicGamer
https://www.flashrom.org/Flashrom
Use a NIC with an EEPROM socket 😀
Reply 25 of 613, by keenerb
Actually my XT-IDE adapter uses a 32kb SST flash, I wonder if I can use that to flash the chip.
Well yeah, it looks like the part number for the xi8088 is the same as the part I ordered for my lo-tech xt-ide card? that's odd.
*edit*
Yeah even HMM'er, I thought that the xt-ide part was 32kb, but it's 128kb * 8, so it's exactly the same part. that explains why I had such a hard time with a second rom that shouldn't have overlapped.
SO yeah, I should 100% be able to use my lotech xt-ide adapter to flash that chip, yay me.
*/edit*
Reply 26 of 613, by BloodyCactus
I have a genius G840, it can do the SST 39SF010A from the BOM. If you get desperate, I can burn it for you. I can burn the SST ones, not sure about the Greenliant ones (probably, it should be the exact same pinout).
Reply 27 of 613, by BloodyCactus
looks like the DS12887A and the DS12C887A are the same. They share the datasheet. Looks like the C version has a century register/byte in the midst of its ram page that the non-C versions dont have.
if the board does not use the ram on the rtc (I dont know), it will be ok.
Reply 28 of 613, by keenerb
Looks like the clock RAM is the cmos setup ram.
*edit*
Aha.
; locations in RTC and NVRAM
cmos_seconds equ 00h ; seconds location in RTC
cmos_alarm_secs equ 01h ; alarm seconds location in RTC
<etc>
cmos_equip equ 14h ; equipment byte
cmos_sum_hi equ 2Eh ; checksum of bytes 10h - 20h - high byte
cmos_sum_lo equ 2Fh ; checksum of bytes 10h - 20h - low byte
cmos_century equ 32h ; centry location in RTC (DS12C887 only)
Looks like the rtc.inc file already accounts for the century location in the DS12C887, and also only uses bytes 10h - 20h anyway so there'd be no overlap.
yay.
Reply 31 of 613, by keenerb
Frys has a 74S74 in stock. I was thinking that should just be a faster version of ALS/LS, but it describes it in the datasheet as an "edge-triggered" flip-flop?
Think that'll work?
Reply 32 of 613, by stamasd
So close, yet so far.
FWIW all 74xx74 are edge-triggered. Go for it. http://web.mit.edu/6.111/www/s2007/datasheets/74LS74.pdf https://www.fairchildsemi.com/datasheets/DM/DM74ALS74A.pdf
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 33 of 613, by keenerb
Ah thanks. The descriptions on mouser/digikey were subtly different, so i wasn't 100% positive. I'll pick up a few today at lunch and hopefully be playing Conquest of Camelot on this just after dinner.
Reply 34 of 613, by keenerb
Frys only had one 74S74, the others are 74LS74...
Still had to order some off the internet. I'll try the 74LS74 and at least see if I can get a boot. May have to disable turbo or it may not work at all, but I'll try...
Reply 35 of 613, by stamasd
Seriously, at 8MHz (and even more so at 4.77) LS vs. S vs. F vs. AHCT vs. ACT vs. HCT vs. ALS is moot. Any will work.
Worry about propagation delay per gate once you get into the 30-40MHz range only.
I/O, I/O,
I/O, I/O
Reply 36 of 613, by keenerb
This is just damned idiotic.
I can't flash with the xt-ide flash.exe because it won't flash anything larger than 64k, and the xiflash isn't usable because it refuses any address < E000.
Reply 37 of 613, by stamasd
The second half of bios128k.bin is blank. I have cut the first half that has the actual code, and am attaching it here. Try it.
Also let me see if I can compile a version of xiflash without the E000 limit.
    bios64k-0.9.bin.zip
    12.11 KiB
    67 downloads
I/O, I/O,
I/O, I/O
Reply 38 of 613, by keenerb
R.I.P. my board, maybe?
I managed to get the 32kb section of actual code flashed but it wouldn't boot. I placed the jumper to enable the on-board speaker (jumpers 1+ 2), powered it on, and immediately smelled smoke.
Turned everything off and re-checked. Apparantly I jumpered 3 + 4, not 1 + 2, so I shorted +5v to ground. I have no idea if this may have damaged anything.
Reply 39 of 613, by stamasd
Try this xiflash, it should have the E000 limit removed.
    xiflash-fixed.zip
    37.23 KiB
    78 downloads
I/O, I/O,
I/O, I/O
