First post, by Rhuwyn
So I am torn. I have an old P2 system I picked up for next to nothing. It's a P2 333 in an Intel LX Chipset motherboard. A pretty nice system in it's day and I really like the style case it has. The bottom of the case however has a lot of rust on it. You can't see it unless you actually look at the bottom of the case. I really don't want to replace the case as most of what I have is more modern. Are there any tricks anyone has used to clean up rust on cases?
Reply 1 of 11, by keenerb
I used vinegar and a ball of aluminum foil to clean a pretty badly rusted Tandy 1000RL chassis. Seemed to work fairly well, needed a little wipedown/cleanup afterwards but looks 10x better.
Reply 2 of 11, by matze79
Consider it as Styling.
images?q=tbn:ANd9GcQKBfOeOx4hcqujg1WGI3rVpo_frxjFaBINzlzti7_PDoZMCEUUZ4sn8M8
http://s251.photobucket.com/user/Simonsaysbak … gge078.jpg.html
Reply 3 of 11, by nforce4max
The only way to save rusty cases is to clean the affected areas and apply some paint or coating but for the worst cases it is best to clean down to the bare metal then repaint. Don't forget the primer if painting cases, as for colors that is up to you. Some people do the same to the plastics are bad or just want a different color.
Reply 4 of 11, by 133MHz
For light surface rust you can't go wrong with keenerb's suggestion of acid and rubbing with aluminum foil - the cool thing about it is that the aluminum is abrasive enough to remove oxide but not so much as to attack the plating or other features. Another suggestion of mine for light rust (especially on expansion card brackets) is to rub with a green sponge commonly used for scrubbing pots and pans, same deal as with the Al foil but it can end up stripping the plating/paint off if you get too carried away. Here's a sample of the sponge method:
dscn1744.jpg?w=800
dscn1745.jpg?w=800
For anything worse you might have to resort to sanding & painting, like I did with the back of this AT case:
gabinete_back.jpg?w=400
http://133FSB.wordpress.com
Reply 5 of 11, by matze79
i simply polished the rusted place and applied nail varnish.
Reply 7 of 11, by Rhuwyn
Here is what I got. it Doesn't wrap around the back much but does wrap around the sides. I might try the green sponge that 133Mhz suggested.
    4.32 MiB
Reply 10 of 11, by Logistics
Since you don't seem to want to tackle this at the professional level, i.e.: sand, primer, paint, then why not just get a can of Rustoleum, mask what you don't want painted, off then bomb it. Like you said, it doesn't show.
Reply 11 of 11, by Rhuwyn
Thanks everyone for their suggestions! That automotive grey looks exactly what I am looking for I think. I think thats what I'm gonna do. I might not get around to it for a while though. But when I fine time I will post pictures back.
